You know what actually the tension of the two camps is probably a good thing for future developments.
Stops people resting on the laurels when designing. If we all agree we'll end up with this situation....
Ever come across the five monkeys and a ladder thought experiment?
People usually fail to mention this is actually a thought experiment and pass it off as a real experiment. Its not. Its a thought experiment based on an actual experiment published in a 1967 paper by a researcher called G.R. Stephenson and it goes like this:
Five monkeys were placed in a cage. In the middle of the cage there was a ladder with a banana on top. As one might expect one of the monkeys raced toward the ladder and as he started to climb, the researchers sprayed the monkey with cold water. In addition to the monkey climbing the ladder, however, the four monkeys at the bottom of the ladder were also sprayed with ice cold water.
A second monkey attempted to climb the ladder and the same thing happened: the researchers sprayed all 5 monkeys with cold water. After a while none of the monkeys dared to climb the ladder to get their hands on the delicious banana, regardless of the temptation.
Once the researchers made sure none of the monkeys was going to climb the ladder, they replaced one of them with another monkey. The newcomer, unaware of the situation, ran toward the ladder to get the banana. But once he started to climb the ladder he was brought down and beaten up by the other four monkeys. After several beatings, the inexperienced new guy learned his lesson: Climbing = Getting beat up. Although he had absolutely no idea why.
The researchers then replaced another one of the original monkeys with an inexperienced one. The same thing happened again: newcomer climbs -> the other four beat him up -> he learns his lesson. The interesting observation here was that the first substituted monkey also joined in to beat up the the new guy, even though he had no idea why he was beaten up for doing the same thing.
The same process was repeated and the 3rd and 4th monkeys were substituted, only for the newcomers to get beaten up every time they attempted to climb the ladder until they stopped trying. Finally, the 5th monkey the last of the original monkeys and the only monkey present in the cage who actually received the cold showers was replaced. The new monkey, naturally, attempted to climb the ladder for the banana, but the other 4 monkeys who had never received cold showers and were instead beaten up every time they tried to climb the ladder themselves attacked the newcomer and beat him up.
If monkeys could speak English, the new guy would probably ask Why do you guys keep hitting me every time I try to get the banana?, and the other four monkeys, after giving each other puzzled looks, would reply Its always been done like this.
Also some people seem to keep using the word FACT a bit inappropriately I feel.
I would suggest scientists deal in theories, they only take each others theories seriously when they are clearly backed by the evidence. The evidence is a clear analysis of indisputable data-sets, covering all the parameters of the system under study. This then leads to the derivation of a theory (
note, not fact, theory), then scientists try to disprove that theory or make it fit the facts better. Can we perhaps then say current theory rather than fact?
e.g. Current theory clearly suggests that HDMI cables cannot sound different. Rather than HDMI cables cannot sound different FACT
Small but significant detail I think
I'm personally at a loss as to why people care so much.
I bought hifi to better my enjoyment of the music I love, how its designed and the theory behind it is not for me. I buy because I enjoy and it enhances my music pleasure. I'm not trying to search for some impossible holy grail from either side. Despite all the science my mood, comfort, time, sleep levels, expectation bias etc etc have way too much influence over what I hear on a day to day basis. That's before we even get into the whole recording/mastering/loudness/bit rate mine field. I can perfectly understand why others would want to try and cut out as many variables as possible, but for others those variables are what makes the hobby fun
I have a threshold, like I suspect most do, on what personally represents foo and what I'm happy with. Given the scientific leaps that are continually being made I think it would be a bit strange to suggest that differences claiming to be heard don't have the chance to be proved correct at some point down the line. But to also not understand that your psychological biases don't influence you is also strange to me.
It constant the jumping up and down shouting I'm right you're wrong that's bloody tiring!
Choose your own reasons to purchase what you do, be that objective or subjective and anywhere in between. Place your opinion with a modicum of understanding that it may not make sense or be right for the person reading it
The end result is to listen to music is it not? if you are you happy with what you have or go onto buy then you are probably doing something right.
Oh and I think I've just proved that some of us talk way to much and should shut up and go listen to some tunes
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
