There seems to be quite a few people who have migrated to direct drive on here recently, particularly thinking of the new Technics models, GR, G etc.
I had one here briefly, although it had to go back due to warped platter, which all got sorted out nicely by the way.
Of course, whilst it was here I did give it a quick listen. Totally stock except an ADC magnesium head shell with an AT100E cartridge.
To be honest, I thought it sounded a bit flat with most music. Dancey stuff with driving beat was a different story, but then I perhaps found it a little too much for a relaxing listen. Great for a party though.
I put the belt drive Thorens back in and didn't notice any difference with Piano, speed stability none of the usual complaints. There were less gaps in the music also, the music flowed out of the Thorens more naturally.
Am I missing something, I see lots of reports about how delightful they are to use, but what about the sound?
Out of interest - how long did you demo it for ?
I can't work out how a belt drive can have 'less gaps in the music' than a direct drive?
Quite amused by people buying a fit & forget DD deck only to modify it. Technics are missing a trick here.
For me the mastering trumps all else.
The best master, converted to lossy 256 AAC played via the headphone output of your smartphone will completely spank poorer masters played on the best vinyl front end.
That aside, the best vinyl front ends succeed by gently bathing the music in a mix of euphonic 'enhancements'.
Vinyl is a pretty lossy medium when all told.
Current mat is 3mm thick RGS0008 replaced old version SFTG172-0
There was a thicker mat back in the day RGS0010 - 6mm
I’m hoping to change my gyrodec for a GR. worth doing you think?I arrived at a 1200G via a couple of Rega's, an LP12 and a Gyrodec. More than happy with mine.
Own both and I think a lot would depend on the arm. With a good arm I'd take the Gyro, I think; with something very basic probably the Technics. In terms of sound AA's right, you'd need to hear both, but I wouldn't expect a big jump in SQ going from Gyro to GR unless you're especially sensitive to what direct drive does well.I’m hoping to change my gyrodec for a GR. worth doing you think?
