What's wrong with the Logitech SB Touch? any reason to change? The Asyc USB connection is hard to beat!
Well if the master thinks it's good... Perhaps I should save the pennies and buy the fusion upgrade (and perhaps a nice pair of staxs).
That reminds me, the other day while looking for the Microscope to examine the Bulk Foil Metal Mask set I found 2 brand new unopened SBT under the lab bench taking up space... If anyone's interest say 200GBP each? which includes shipping to anywhere in Europe....
Brand new units seem to be going for a lot more on Ebay these days... I could do with the extra leg room
Yes - definitely the better option - the SBT hard to beat with the Async connection
Would yourself and/or Dominik find having a SBT around for testing Async compatibility (up to 24/192) with the USB 2.0 implementation in the MDAC2 useful?
If DAC's are female, how about LaDAC?
Dear John,
I just wanted to send a follow up message in regards to putting myself on the list for an upgrade. I didn't really receive any confirmation as to whether I was accepted onto your waiting list with the first message. I don't quite know which upgrade route I wish to go down just yet as it seems there are quite a few options available to myself. Saying that, I imagine it is going to be alittle while before I have to decide.
Kind regards,
Harry
Fusion: we need more feedback!
My understanding is if you start with a DSD file the media player has to encode it into PCM packets for DoP. I don't think you can buy/download pre-packaged DSD files.As for the players - I believe any "bit perfect" player should be capable of "playing" PCM-encoded DSD data. It's still just PCM bitstream to the player / driver / streamer hardware, if I understand it correctly. Or is there some "pure DSD" non-PCM-encoded format, playable via proprietary drivers?
Yes its a resistor swap, however it involves removing SMD components and once the resistors are replaced with the Bulk Foils the Analogue stage needs to be adjusted - so the Resistors swap is not a simple DIY job.
Yes the MDAC2 PCB will be designed fromm the start to support AV bypass
You can route your Analogue sources via the AV bypass input - then using an analogue pre-amplifier you can adjust (and select) the level of the analogue sources such as your turntable etc.
Oh Yes, same connector arrangement as the MDAC but with the extra AV bypass conectors.
John,Jiri,
Dominik has all the details - contact him via skype chat - I'm sure he will be happy to talk with you...
If you have not already seen this site:-
http://dsd-guide.com/technical-documents
