its 9am and already 28.6DegC Im already topless![]()
...too much information!
...too much information!![]()
Hi John, do you have any experience with the first 12 "Tyco" L2-Upgrades and "Toy" on top?
Hi John, thanks for the detailed feedback, I hope my black unit responds as well to the 'Toy' upgrade...![]()
John, is there an easy way to use the power supply from one of the non-constricted-sounding DACs on Johan's unit? Soft bass, constricted sound - might well be a power supply issue.
I know (and fear) that when Jems’s unit is fusion’ed – its going to blow Johans unit out the water, ......
Why not give it a go, really want to know how far fusion is ahead of toy on a fair ground, not 2 different mdac.....
I’ll list the units we listened too and summarized the modifications made:
1. Johna’s Fusion unit with x4 100pF added for extended stability & 9600pF of BCcomponents capacitors in place of 10nF EVOX PFR’s
2. Jems “Silver Unit” uncased with L2MDAC upgrade with Dale resistors.
Johans "Fusion" with the “extra” x4 100pF removed opened the sound stage up even more! and increased detail, but did not resolve the Midrange hardness.
The next move was to replace the 9600pF of BCcomponents capacitors (which had Magnetic leads) to Wima’s 10nF which where non magnetic – this banished the midrange harness never to be heard or mentioned again.
Now the Johans (black) Fusion’ed unit excelled with Clarity, “Smoothness” to female vocals, incredible resolution – and "Tyco wide soundstage" – foot tapping was back (but Jem’s unit was still very slightly ahead in this regards).
... I know (and fear) that when Jems’s (silver) unit is fusion’ed – its going to blow Johans unit out the water,..
Yesterday was an exhausting day
is there a measureable difference in noise between l2+dale resistors and l2+vishey bulk resistors? i would not be surprised if the resistors is a limiting factor.
btw: i know a alternative way to measure noise, just use a amp with very low noisefloor, use highest possible volume and put the ear to the speaker, a emty track or a track with very low volume needs to be used(a bit dangorus).
Taken your time John.
Rather have it good than fast
