OK I'm sorry for the bad news, but all those 13 units I've thus sent out will need to be return to me at sometime to be updated with the Bulk films x4... I'll pay for the x4 Bulk Films + return shipping as compensation for the inconvenience of having to ship them back to me...
It’s STUPIDLY good!!! I CANNOT believe how good even Johan’s unit now sounds (even with what ever is still “constraining” it) - I simply cannot! The amount of pure resolution these 4 resistors have brought to the table!
I can clearly hear this extra dimension and realism even though the “constraint” of Johan’s unit (indecently SimonOm units has the same constraint – so I’m now really suspecting the “Blue” 220R resistors as fitted to both units are at fault – otherwise its going to be really hard to find the cause).
I think I might a theory as to “How” these resistors are having such a dramatic effect on the sound quality– a logical explanation is that the "Quality” of the resistor is being “Magnified” by its function within the circuit – its part of an “inner feedback loop”.
As a theory I like to put forward that the forward gain of the amplifier “Magnifies” the quality effect of this resistor – there’s about 120dB forward gain, so I suggest that the “Quality” of the resistor is being “magnified” potentially by a factor of a million – hence it should no longer be such a surprise to anyone that this component position has proved to be so sensitive…
In “layman’s terms” think of a throttle control for a 1,000,000 HP engine – the throttle is going be extremely sensitive especially when driving a very light load – this is essentially what’s happening in this application. Any slight movement (or non linearity) of the throttle peddle is magnified by the MASSIVE power of the engine.
Thinking alone these lines and I can now better understand why others have reported improved sound quality with lower open-loop gain amplifiers (think lower power engines) – its not the Open Loop gain level that’s the problem, rather the linearity of the feedback components (the quality of the throttle control) being magnified by the open loop gain (Engine power)…
When you start to magnifying anything by a million times all kinds of odd effect are going to start coming into play... atleast I don't have to feel that I'm going mad... (just think "Magnified" by a Million times
No way I'm gonna let you pay for my bulk foils, and the only bad news is more work for you, I hope you will find a youngster with good eyes and a steady hand to do the upgrades and make some money for both of you. It seems the wizard needs an apprentice
The dedication and persistence you perform is admirable, and valuable learning for a lot of us.
The magnetism may not be the single biggest fault of the resistors, even though I used to learn to make resistors from the late great Steen Duelund, all magnetic and plastic where banned, silver connections where made and even resonance optimization where done on my own resistors.( 2 watts resistors are big enough to make for normal hands )
there must be someone out there to share experience and opinions regarding good sounding, nonmagnetic, reasonably priced SMD resistors ?
Searching the net I found out the late great Allen Wright (Waccum State Electronic) banned some "mini-MELF" resistors for the magnetic end caps already in 2004, unfortunately he did not give a favorite, seems he was still searching at that time:
(( Copy:
"Posted by Allen Wright (M) on December 26, 2004 at 12:34:29
In Reply to: Non-magnetic SMD resistors? posted by Henry Pasternack on December 26, 2004 at 11:15:12:
...is to test them yourself with a magnet!
I have no experience with the 1206 series, but went through several of the 0603 types for our attenuators to find one that wasn't. Many SMD chips (Caps & R's) seem use a nickel based sludge to make the terminations, and that's magnetic enough to be less than optimum.
>"audiophile approved"?<
Dunno -but be aware that quite a few of the1206 series are "metalglaze" and I'd expect these not to sound as good as the normal metal foil versions. I'd expect the bulk metalfoil VISHAY SMD's to sound really good, just like their regular bulk foil R's - and cost pretty much the same as well!
What I don't like are the tubular "mini-MELF" range that uses pressed on endcaps just like a normal wired R - that's SMD R's main advantage - IMO.
Seasons greetings, Allen"
Another opinion from the web:
(( "The winner?? The only SMT resistor worth listening to was the SMT version of the Roederstein through-hole parts. This is no surprise, because it is exactly the same part, but without the leads. It pretty much sounded exactly the same as the Roedersteins, which are still some of the best-sounding resistors around. They are in a MELF package, which is kind of a pain, and they have the steel endcaps, which I still don't get. How in the world they can sound good with steel endcaps is beyond me." ))
I don't get it either
I'm sure the bulk foil will sound beyond belief in places where it really matters, and no doubt John will know, (and listen to be sure), where it does, but it seems we might need suggestions, for good sounding, nonmagnetic, reasonably priced SMD resistors to be approved by John, for at least the 47R ?
.... Just to save around 250GBP each SuperLevel MDAC
and for "NotDarkSide" L2MDAC ? (all the SMD resistors)
......and for future.......LakeWest products ?
Anyone?
Even just www rumors...?
I hope Renata will feel better in the morning
