Hello everyone.
I have come here in a bit of desperation. I have searched through the MDAC first listen posts, and even though I see a lot of people with the same kind of problem I don't see a resolution to it anywhere.
My problem is with my MDAC, every once in a while it emits a popping/cracking sound. It is driving me to distraction.
I purchased an MDAC last year, only to have serious problems with it. The store where I obtained the MDAC were nice enough to replace it for me after much ado and the new one has been playing up intermittently ever since in different ways although this one worked enough to play music.
I probably should have taken this one back and just tried to get my money back but I didn't want to become a "problem customer". Also it sounds great aside from the popping noise. (You can hear it over the music)
I have tried just about everything I can think of, from different settings in the DAC itself to removing all the USB devices attached to my PC. In fact it does this when not connected to my PC at all, just with the DAC connected through either of my amps.
It does this whether connected via USB or coax or optical. I have tried different cables. Different USB (Always 2.0) ports. On different machines. I have also tried RCA and XLR outputs. Again it's the same.
I have tried different firmwares and am currently using the latest from John's wiki (Windows 7).
The only slight anomaly I can give you is that every once in a while there's two pops, right after each other maybe a second apart, then back to one for a while.
Finally got to the point where I just couldn't take it any more, I thought I would come and ask John or any other knowledgeable people
. Has anyone got any idea what this might be?
-Tim
