Julf
Facts are our friends
What is it supposed to do, and why is it needed?
Well, the MDAC does it whether it's connected to my PC or not so I kind of figured it wasn't the software.
The software I use though is iTunes or more likely Foobar2000. The Buffer settings on Foobar have changed a bit trying to cure this problem to no effect, but I use 1k-1500 usually. I used to run it with ASIO but haven't done that for some time.
Other software I use are Cyberlink video player, VLC, Windows media player. I think that about covers it, aside from internet browsers and flash based things.
Thanks, but I don't know about that USB thingy. My MDAC is doing this when it's not even connected to my computer.
Hi Tim,
From your description its not a known problem - so your unit must have a random fault - where are you located? If your located in the UK, and your unit is still under warranty then I suggest sending it to Audiolab service centre with a clear description of the fault as it can be very hard to reproduce an issue like this if you are not aware of what your looking for...
Go to the website to read up about it, I believe they offer a trial version for you to listen, although it cuts playback for a few seconds once a minute because it s a demo
http://jplay.eu/faq/
It basically decodes the entire song to the computers ram and plays back from there, so the song is not affected by other processes the computer is running.
Read the reviews, try the free demo and you can decide for yourself
http://6moons.com/audioreviews/jplay/1.html[/url]
are you using mp3s?
Let me guess, the next one is about my system not being resolving enough, and then probably something about my ears?
Hello everyone.
I have tried different firmwares and am currently using the latest from John's wiki (Windows 7).
-Tim
Tim - Could you hold down (push in) the rotary dial and power the machine up from the main on off button.
You should get an exact confirmation of which firmware it is and some stuff about voltages.
You can get popping on the Coax and Optical if the output from the source has jitter or a wandering clock. The later firmwares have a Jitter rejection option that can be set to wide (this option is specific to each input, so if all your sources are jittery - you need to set it for each of them) Somethings (e.g. Apple TV) still have issues.
Problems on USB are usually buffer related. There is an option that shows how full the buffer is on the M-DAC. It should sit at 45-55%. If it is wandering up and down, then the problem IS a buffer issue, you can visually see the correlation between the buffer dropping back down and the popping noise.
I think you might just be unlucky in that you have had both types of problems....
What's the low end of an acceptable voltage ? Mines dropped 14.9/15 v . Would the fusion mods have altered anything , as it was never this low ?
