Ok, latest development is to added position for "headers" on the MDAC2 PCB which will allow us to add the Tube output stage at a later date. So owners of the MDAC2 can "Upgrade" to the Tube platform one its released (the MDAC2 will have to be returned to Czech Rep for Tube option).
Unfortunately, the difficulties with the "TDAC" is not so much the tube circuit itself, but we will need to rehouse the MDAC2 PCB + Tube section with its extra PSU into a new chassis - its this new chassis that adds the extra complexity. At this time, I'm not sure how we will handle this... Maybe Arek can help out the Mechanical work, I dread European pricing on Mechanical parts
As Ive now come to terms with the fact that the MDAC2 design will be based on 2 PCBs the logical step is to totally isolate the Digital and analogue stages so one PCB contains the Dual ESS DACs, Clock, Analogue stage and PSU. While the second PCB (mounted above) has the FPGA, USB and digital inputs etc.
We can add a galvanic isolation barrier between these 2 PCBs so the critical Analogue stage is isolated from the Noisy digital sections, insuring the lowest analogue ground noise. While added complexity to the project in design time its has many advantages not least that its really the correct method to do it:-
1. Should practically eliminate Second order digital processing effects on sound quality (Sound quality should not be effected by software routines etc).
2. Provides galvanic isolation from the digital section if the additional PSU is installed (an option).
3. Provides a future upgrade path (either the Digital or Analogue PCB can be upgraded in the future at reduced cost without scrapping the whole unit).
4. Allows as to pre-release a simpler interim Digital board very quickly (no FPGA and only supporting USB upto 24/96) so basically the same functionality of MDAC but with the improved sound quality of the MDAC2 (Dual ESS + new output stage etc) with galavincally isolated USB etc. This allows those waiting for the MDAC2 to gain the improved sound quality ahead of the official release of the fully featured MDAC2, the extra MDAC2 Digital features can be added later with a simple board upgrade by the owner with the fully featured MDAC2 digital board.
This de-risks the project, allowing us to swiftly deliver the basic improved sound quality of MDAC2 while we continue the development work on the more advanced digital board with the promised features (DSD64, 128, 256, PCM 384fs + FPGA etc), so now a 2 stage process, but allowing us to deliver the MDAC2 "Sound quality" closer to the original target dates
MDAC2 audio performance will be further improved once we start introducing the more advanced FPGA firmware upgrades (upgraded via a software download) these will incorporate a more advanced digital filter etc
The "Interim" Digital board will be sold at a nominal cost to cover its production and development (lets say around GBP150).
Comments? (Good idea or bad idea?)
