PhilCTTE
Senior mumbler
Well I was going to post some measurements of the Quad 520F, but the performance is so unbelievably bad, that I need to regain my composure.
Its not a problem as the intention is to totally redesign the unit - serving as a prototype on the MAMP / MIMP etc. I guess I'm just so surprised that the product was ever approved and sold like this... Quad must have been going though some very bad times to have such a poor level of engineering... I must say, I've lost a lot of respect for them after seeing this design.
I thought my Quad 240's where bad, this design is even worst... basically poor PCB design, but the circuits not great, but no reason why it should be any worst then a Quad 606 etc - in fact it has a larger PSU / Heatsink so it could have been better...
Eek and I've bought 2 of them. I have total faith
Perhaps the sock will come in useful when you listen to it ...
Will you listen to it before dissecting? The none serviced one you have sounded rougher at both ends but a fuller bass. At first I thought it was better and more solid bass but decided that there was just more of it, as I noted previously. I level matched it by ear and turned the input trim down, so it want just the volume at play.
Hope it helps with your design implementation.
