misterdog
Not the canine kind
I have no axe to grind .
So why waste your time and ours posting then ?
Do something constructive with your/our time.
Listen to music , for example.
It's only Hi Fi.
But I've not played with the gain controls on the back yet. There is one per channel with no markings though so it could be tricky to get them the same.
Would something like Van Damme Starquad Cable do the job? I'm already using that between my MDAC and EAR890.
I didn't think you would resist that! You got your value in scrap metal alone!
It's a thirsty amp by the way, about 150w at idle, goodness knows what at other times, particularly on power up to fill up the big filter caps, could give a delicate switch a hard time. So I switch mine off when not in use! The advice I saw and have followed with my Parasound (predecessor model to yours) is to give it a dedicated wall socket, and I also put together a rather meaty power cable (you may have got the supplied one with yours which was supposed to be decent).
I also have a neighbour issue, damn, when you've got an amp like that you just want to go higher and higher! p.s. ask them to let you know when they will be out - works a treat!
Only trouble I might have is the volume levels, I'm at about -40db for casual listening and -30db for proper listening
The other joy of Van Damme Starquad is that it costs less than £ 2.00 per Metre.
I have 15 M. running around my room
Imagine the cost for a boutique cable.
Before I ran Active I had some speaker cable (2 times 3M) costing £700 (RRP)
Guess which I prefer.
I always leave my power amps on standby plugged directly into wall socket and use a 12v trigger to switch them on from AV receiver. My Mdac is plugged into a Tacima power strip which has rf filters and surge protection. All my Hifi is on same spur from living room ring, I might look into a remote switch to power it all off at some point. What you want to ensure is that you don't choke your power amps by inserting some lesser spec power conditioners/filters , so will a remote switch which I assume is built into a power strip restrict anything. I,d look at getting your electrician in to properly spec out one which is built into a spur.
Wow just read other posts 150w at I idle !
Just reading Johns post (*blush) , of course if you are not happy in anyway with the cables I'll be happy to offer refund,
The same levels as I,m experiencing , can't adjust mine tho
Is this what you're talking about http://www.amazon.co.uk/Designacable-Custom-Length-Neutrik-Microphone/dp/B009FZX5DU/ref=pd_sim_sbs_MI_4 ?Been following this posts for as long as I've had my M-Dac, this is the first I've seen posts on the legendary Van Damme cables, i upgraded form Atlas Hypers and The Chord Company interconnects to Van damme Hi-fi Series and Van Damme Silver Series Session Grade Instrument interconnects. WOW JUST WOW sold my atlas and Chords and now i have enough money for upgrading my power amp (wife restrictions in and out policy) so i look for some assistance. I have the Audiolab 8000p picked up second british serial number "E" for £150 a year ago i my budged its up to £800 would the Parasound 2125 be a massive upgrade? or should i be aiming higher?
Just need John's new amps when they're ready![]()
I'm not using XLR into my audiolab 8000 so I'm using these
http://www.vdctrading.com/shop/van-...grade-lo-cap-55pf-instrument-cable-per-metre/ with Rca plug's
But I will be obtain those if my next power amp supports it. Out of interest what power amps are the majority of mdac users preferring?
That's what I use except mine are Black![]()
I made my own cables up and used the silver plated XLR. Pretty good price that though.
with 30k+ Mdacs out there we actually hear of relatively few failures. With John looking at complete Euro production and supply chain for the Mdac2 I bet he manages to slash that rate.
The ones inside my active Adams
cuts out all the worry about Impedance matching etc, etc.
and hence allows more time to listen.
By 'we' I meant, us, forum members, mdac owners, people who bought an Mdac with their own money. It's sad that soem people seem to have nothing better to do with their time than make up pocket conspiracy theories. Stilgoe, is Englsih your first language?
