I mention briefly in an earlier post, but on the prototype analogue stage PCB I'm working on the Balanced output connectors are a 5W XLR types to facilitate "Remote feedback Sense" where the feedback signal is taken at the end of the cable run thus reducing / removing the sonic effects of cables and connectors.
The idea behind Remote Sense feedback is that the external cable and connectors are nor included within the MDAC2 feedback loop and any "errors" such as cable resistance & capacitance will be sensed and corrected - and one would hope remove or atleast reduce "cable sound".
Taken a step further, and the RS can be extended internally to compatible power amplifier designs (MIMP / MAMP) fitted with 5W XLR audio inputs so that the remote sense loop now includes the amplifiers input connector and a section of its internal signal path...
The remote sense feature can be enabled via an onboard relays so I can (once again double blind) toggle between standard and remote sense option to see if its worth considering as a production variant.
The remote sense makes even more sense for high Quality headphone users... (with a custom cable and dual 5 pin XLR's).
If the results prove positive then MDAC2 will be offered in two variants Standard or Remote Sense (RS) we can add go-faster stripes
The complication of the RS version would be the requirement for custom cables - but we "suspect" that it will reap such a benefit that we will be forced into the "complexity" of providing the solution.
I requested decent quality PTFE 4 core + shielded cable sample from Chord - who I'm thinking along the lines will proved the custom cables.
As I say, if the results are positive, then the we will still offer MDAC2 with "standard" 3 Pole XLR's for those who would not need the feature (as it limits the cable choice).
The RS is only applicable to the Balanced output (and balanced driven headphones), the use of Single Ended RCA is so suboptimal anyway....
