As we discussed in the car, using the switch on the back-panel-mounted XLR socket wouldn't be a good idea if one wants to use the front jack to switch between rear 5-pin XLR and rear dual 3-pin XLRs. Unless there's some logic I'm not seeing, the only possible solution to that is to have two states based on the status of the front jack socket switch:FYI - the Neutrik 5W XLR's I bought for Jiri (RS 694 9409) have a detect switch (the original plastic moulding appears to have been hand milled and the switch glued into position)!!! Like you I'd never seen a XLR with detect switch so it was a nice surprise - I'll use the switch to detect "XLR inserted" and thus select between front or rear headphone outputs.
- front socket empty - output goes to dual 3-pin XLRs - and - RCAs (ie. speakers)
- front socket occupied by "something" - output goes to 5-pin XLR - and - front headphone output
Or is the idea based on expanding the "front socket occupied" state by another condition
- back 5-pin XLR empty - output goes ONLY to front headphone output
- back 5-pin XLR occupied - output goes ONLY to back 5-pin XLR output
That could actually help with possible issues caused by the front dummy plug.
