JohnW
pfm member
what filter is mostly used or the best? Minimum?
Optimal Transient XD for me
If you're serious you'll need a pair... Run in bridged mode!
I could be wrong but I read from John's post (#842) that both versions would be based on V0.90, so not sure what you are referring to.
Or compare bridged vs. bi-amping.![]()
I can't go back to the original version, because there is no Mac version of it. So I am waiting for the new update very much. Any idea when it s coming out?
Indeed. Although I need a pair of MIMPs before making extensive SQ comparisons.
Optimal Transient XD for me![]()
I tried & tried with Optimal Transient XD, but it narrowed the field of sound considerably.
I'm running a pair of B&W 805 Signatures with a Bel canto REF 150s Power Amp & the M-Dac XLR. Standard M-Dac setting.
Strange how we all prefer different sound reproduction. No right or wrong - Just choice![]()
My MDAC is having trouble locking at 176.4 at times. Is this a known problem? The music starts to chop and distort and the display starts to flicker like crazy. I've tried both ASIO and WASAPI and also different latencys and nothing seems to help. It's odd, because if I try again five minutes later it often starts working again.
Yes, I'm using coax. Sorry, forgot to mention that.Guess your using SPDIF as USB does not support higher then 96KHz.
Have you tried setting "Jitter Rejection" to Wide Bandwidth
That's what I'm thinking.
If bought as a pair, do you think they would be matched and balanced (rather than possibly needing to use the MDAC balance control)?
fresh from the oven - vA.09:
https://www.box.com/s/ni1655nxjcg9fcngnf0v
- based upon original v0.90
- includes most of the UI features introduced over time
- custom input labeling
- mute working in DAC-only mode
- CD emphasis detection & de-emphasis filter
- fixes OPT1/2 discrete remote codes
Mac release will follow later as well as a new version with more features included..
Typical.... my MDAC is somewhere between the UK and the Czech Republic so I will be the last to the A09 party...but one of the first to the hot-rodded MDAC party
