Thank you for getting back to me John.Harry,
This is certainly an odd issue - one I'd certainly like to understand - if only out of interest as to understand what's happening!
Couple of things spring to mind – maybe the amplifier’s input stage is being overdriven by the MDAC’s output level – or maybe Hi-Levels of Low or even High frequency energy is upsetting the amps input stage…
Have you tried with the MDAC set to -1dB, (I'm presuming you are using the amplifiers level control)?
If reducing the MDAC’s output level resolves the issue then it’s the input stage of the amplifier unable to cope with the MDAC’s output level (its about 2.3Vrms “Peak”)…
I normally have the preamplifier disabled, and just adjust the output on the Quad77. Having just reversed this process, I find that when I reduce the output to -1dB I almost get rid of all the clicking but it is only when I go to -2dB that it completely disappears. So both of our initial theories as to the cause of this problem stem from the possibility of the the output of the M-DAC being too high for the Quad77 (something that could be possibly rectified by altering the input sensitivity on the Quad77, although I do not own the remote control that would allow me to do this).
However this doesn't answer the much more interesting effect of changing the filter or even altering the macbook bit depth and sample rate to something higher then the actual bit depth and sample rate of the music file being played (ie from 16bit/44.1kHz to 24bit/96kHz). Either one of these changes will stop this issue.
How about this other strange phenomena too? The Quad77 integrated has 32 interval steps from zero output to maximum on the volume control, (admittedly not linear, with bigger incremental changes for each of the first half or so steps of those output power selections). When the volume is set between 1-10 is when these clicking/flicking noises present themselves (remembering this is only on a few tracks), at the same perceived volume level whether at 1 or 10. Suddenly disappearing at 11 or above. Possibly masked, although I am really listening intently to see if I can pick up these artefacts and I am struggling at 11 on the volume control. Also remember that with the headphones plugged in, this is a non issue too.
Weird.
Let me know what you think.
Kind regards,
Harry
Just to add, apparently the selectable Quad77 integrated sensitivities include 100mV / 300mV / 775mV. I'm not an electrics expert or engineer by any stretch of the imagination, so make do with those figures as you will.
