Dear John, Dominik,
Having just installed A.90 having been a A.08 user, I certainly feel that there is a positive difference. I feel the bass response is tighter, and that there is better separation of instruments leading to a more defined sound stage. Now my memory retention with these relatively small but important improvements will be pretty poor if I had to do a blind test (I'm not that old!!!), especially considering the amount of time that would be required to re-update the M-DAC in between listening to samples, so only time will tell how much of this is expectation bias vs real significant improvements. Having said that, I am very pleased with the initial results and I am grateful for all of your hard work.
In other news, I have a bit of a strange situation going on here that is not exclusive to version A.90, which I think I know the cause of, but will mention here for your perusal. Don't hate me, but I am an optimal spectrum fan. I personally find it the most dynamic, and yes it is bright, but aged 25, I am able to enjoy that higher frequency response ;-) Anyway, the issue I am having is almost certainly not the fault of the M-DAC but certain selections on the M-DAC appear to totally eradicate the problem that I am having. Essentially, the issue that I am having is only replicated when the optimal spectrum filter is in use with the appropriate nominal frequency sample rate and bit depth input matched to the music that I am listening to (exclusively through USB). The problem I am experiencing is sharp clicking noises of varying intensity and duration during playback through my Quad 77 integrated amplifier, usually when the bass of a track kicks in. If I change any of the above conditions, i.e. the filter/macbook bit depth+sample rate output/or even slide the digital volume (effectively altering the bit depth) this issue is non existent. Actually, if I take out the Quad77 out of the equation and just use my headphones, there is no issue. So as far as I see it, the amplifier is at at fault, but why? Just to add, this issue is only replicated with a certain number of tracks as well. My only guess is that certain transient peaks seem to play havoc with the amplifier. If I increase the amplification on the Quad77, this also seems to alleviate the problem too, I.e. as far as I see it, the clicks are of a fixed amplitude when the symptoms are presented. I know that with the appropriate remote control for the device, one can change the input sensitivity on the Quad77 and I'm hoping this is the solution but I cannot test that since I do not have access to such a remote unfortunately. If this isn't the solution, I have to admit that I am quite clueless here.
If you happen to get a chance, I would love to get your opinions here.
Kind regards,
Harry
ps. with the optimal transient filter, I find the soundstage more revealing/wider then with optimal spectrum, but as I mentioned before, at the expense of a slight reduction in dynamics. Just my opinion anyway.
