Its worst, this is the labs Main fusebox waiting to be completed :-
What is the best solution:to buy usb to spdif convertor for laptop or cd player for mdac?thanks!
Yes, I have been there!
(My barge fitout during the great connection - 12v/24v side)
Neil,
You got more fuses on your Barge then my LAB![]()
On the mdac display apear 24bit/96 khz but no D3e.it's ok?
Disco balls , hot tub ummm ...
JohnW
Txs for taking your time to show me your new lab and the MDAC2. I can assure everybody that the board is first class, and it all look's SO exiting.
Could it be ' the last dac you ever need' ( and I have A LOT of them ).
Your new Lab is second to none, and you must have used a small oak forest for it.
I promise to call next time im near.
Best
Theis
I especially like the Push Monthly button.Yep, can see it now, Disco ball in a low ceiling barge!
No Disco ball here:-
https://dl.dropboxusercontent.com/u/86116171/Lab Fuse Box..jpg
Now time to build the PCB![]()
Here's the Vishay PBG12201 Bargraph module (110mm High) - I managed to source x50 Pcs of these discontinued panels
Its basically a Plasma display panel - with 100 elements per Bargraph, which will give very nice fine level meters for Output level, Current output, Temperature etc.
https://dl.dropboxusercontent.com/u/86116171/Vishay PBG12201.jpg
Orange!!!
