Orange!!!
Nice, it will look warmer...
Orange!!!
Does it seem feasible that a dodgy connection in the ribbon might cause it to power up but decide it was "unlocked" or would there be some other reason for that particular fault mode?
or is this likely to be a symptom of impending further doom (eg. motherboard crystal)?
Will you possibly have some spare ribbon cables available for the MDAC2?
I was surprised when I took the boards out, just how much of the mainboard has circuit laid out on it but no components.
What was that for John?
(I suspect if I read back through the original Audiolab threads I'd find out, but is seemed easier to just ask you )
Its 99% chance the problem was due to the incorrectly connected cable - or the FPC is not "cut" 100% correctly and it require several trials to insure its was correctly centred with the mating contacts.
No, that fact you originally had a "No Lock" indication suggest that the Cable was not correctly fitted.
Yes, we will supply with a new FPC cable.
For the originally planned "QDAC" which included the Analogue Pre-amplifier (the same design as the CDQ's Analogue pre-amplifier stage). However we could not afford the extra Heat dissipation due to the extra loading on the small regulator heatsinks.
The MDAC2 uses a "Heatbar" that runs the entire length of the Digital PCB just behind the front panel to increase thermal dissipation.
http://imgur.com/H619uI9
Naked MDAC definitely sounds better to me, now clothed in pine wood. Plenty of ventilation holes so hopefully no heat problems
http://imgur.com/KaA2nGZ
Hi JohnW,
How late does one need to commit if they're interested in some slave MDAC2s?
Might be tempted to go active crossovers, once I've switched to DIY speakers.
Ta
23.5"L x 31.5"D x 63"H (before packing on a pallet or what have you).
Something like http://rover.ebay.com/rover/1/711-5...0001&campid=5338728743&icep_item=261583000928 - then connect it via toslink to the MDAC.Hi all,
what is the best way to feed MDAC2 with a HDMI source? What kind of device I need? Any suggestion? Thanks.
