Yes I know. The answer? Try it for free and make up your own mind.
And if you don't like it, can you remove it so that you can be sure that it is completely removed?
Actually you can. Take a restore point before you install it, then revert to the restore point once you've done your tests
One potential reason why it may not be complete foo would be if you're reading off a local hard disk and it introduces noise artefacts as it is accessed.
Putin does look good semi naked on a horse though.![]()
But don't most player programs use fairly big RAM buffers anyway, so the possible noise would only occur for a short time a couple of times per track - and wouldn't any other activity on the computer cause similar noise?
More Likely is that the hard disc is randomly accessed by the operating system at any time.
Just tried WASAPI in Jriver and did not like the sound. Previously I was using ASIO4ALL. I didn't do a bit perfect test on WASAPI but set it up for bit perfect playback. A while ago I loaded the bit perfect test files and they passed with ASIO4ALL. Quite odd the sound seemed harder in the top frequencies and lacked the usual depth. I wasn't expecting a difference but changed to WASAPI on seeing a recommendation on the Jriver forum. It seems I am not alone as someone else has found this albeit with a different DAC but with the same ESS chip, which may be irrelevant.
http://www.polkaudio.com/forums/showthread.php?136141-WASAPI-vs-ASIO4ALL-Kernel-Streaming
Anyone else found this?
Re JPLAY, read what it has to say on their website about what it does. Amongst other things it closes down all the unnecessary activity on the audio computer ( I operate it in the optimal dual computer mode).
The difference in SQ between jriver and JPLAY is not subtle.
As I said, try it
Do we need to duplicate this discussion / arguments on JPlay?
Please see http://www.pinkfishmedia.net/forum/showthread.php?t=138194 first.
Sorry, but if transfer mode is asynch (with MDAC it is), bit-perfect and there is not much RF leakage / or properly isolated, there can't be any difference. Try double blind test.
different bit perfect software players do not sound different and have never been shown to do so in controlled tests.
My new, Win 8 ,USB 3 laptop sounds better than my old Win 7 laptop.
Yes, the different inputs on the Mdac do sound different. different bit perfect software players do not sound different and have never been shown to do so in controlled tests.
Both passed Bit Perfect.
Surprised me, as I wasn't expecting USB 3 to work at all.
Win8 audio is different to Win7 (see disabledynamictick re DPC latency) but then both passed the bit perfect test. However the PC hardware has changed + USB version is different. So you could be listening to RF effects/absence of, unless you're using an isolator with both PC's?
Cheers
