We had some rain lately. Meaning, temperatures go down. Meaning, some work can be done.
To take you a few pages back, when I completed the "new" motor pod, I also did a so called vanity motor cover, in the vein of Micro Seiki, to ensure that mounting screws, pulleys, and belt flex remain hidden, so that the visual focus is locked to the platter rotating. What that looked like, in more detail,
can be ascertained here:
However, due to rim drive implementation, I had to (1) make a new pulley and (2) add a new, smaller belt with a lower transfer ratio, leading to a narrower belt flex angle. A direct result of said changes is that the current motor cover is practically unusable. Furthermore, the rim drive additionally helps reduce visual distractions by eliminating the belt around the platter, so the missing motor cover irritated me immensely (first world problems, I know).
To aid you from having to scroll through earlier posts, here is what the rim drive looked like without said motor cover:
Unlike the existing motor cover, I decided to go the way of POM as opposed to aluminium. Apart from deciding that white POM matches the rest of the turntable aesthetically (by adding proper contrast), a more important reason is the minor problem I experienced with the earlier motor cover,
as described here (The aluminium cover acted as a horn and amplified the pulley noise to the point of bother during quiet passages). POM has a different damping range, so that issue should be, at the very least, decreased.
Once machining has been completed, the new cover looks suspiciosly similar to an ashtray:
Yet after being put in place, the world is now at peace:
There is no inherent noise due to the cover, no added vibration due to the soft coupling, and the eye sore is gone, so there is that.
Onwards and upwards.
