InSides
dŵr
Introduction
I've dabbled with analog reproduction for more than half my life. That seems like much, but then again, not as much as many other enjoyers of this hobby. And then, dabbled seems like the most appropriate term for a non-English speaker, as what I am doing can be described most aptly as 80% enthusiasm, 10% science (perhaps) and 10% sheer stubbornness.
I was unlucky (or lucky, depending on point of view) to have limited access to turntables and the general analog reproduction techniques, as interest in vinyl had waned dramatically at the beginning of the 2000's. I did own, over the years, a number of hi-fi turntables (exclusively belt driven) and quickly understood that I would not be happy until I either (1) purchase a turntable that I could not afford or (2) build one.
Option one was out of the question. Option two required a few years of learning, research, drawing, inspecting materials, prototyping, chasing machine shops and finishing houses, and listening. Little did I understand at that time it would not be the cheaper option.
This thread is started in response to feedback on the System Pics 2020 thread, and is meant to describe some of my efforts related to turntable building, as well as shed light on motivation and approaches. I will be reusing material I have posted on my native forum, and translating where needed. As such, will need to do several posts before I get up to date on the current happenings.
I tend to write longer posts and typically follow up with a lot of photos. You have been warned.
Turntable
I decided to call the turntable dŵr.
To a lifelong fan of Orbital, the reference should be obvious. To a teenager in the 1990s, almost inevitable. As I understood it, it is the Welsh word for water, which also seemed natural a name to describe the freeflowing shape, and ease of reproduction of the turntable it came to represent. Unrelated to this, in my native language, the pronounciation of the word also refers to a key musical term.
So it stuck.
A mass-loading affair, there is no suspension to speak of. The turntable has been designed to work together with the bespoke rack, rounding of a concept to gather and sink unwanted vibrational energy instead of damping it.
Plinth. A bespoke laminate of beech and maple, arranged against the grain for structural rigidity, the shape of the plinth is a result of its function. A rounded triangular form with pillars at the apex points, and a central thicker section to house the bearing block. Carved on a CNC, sanded by hand and finished with beeswax and linseed oil to avoid lacquers.
Pillars. The plinth rests on three damped pillars which also serve as tonearm mounting points. Machined out of 6082 aluminium, each pillar consists of 8 individual components which help (1) clamp the plinth, (2) mate ball bearings with the shelves of the rack, (3) dissipate tonearm vibrations and (4) facilitate the mounting of tonearms with a wide specter of effective lengths through cantilevered mounts. The ball bearings are Silicon Nitride ceramic balls (Si3N4) with the highest sphericity rate available to me commercially. Arrangement of said balls follows the kinematic bearing principle allowing for self-positioning.
Bearing. Non-inverted single piece bronze sleeve to dispense with mating bushings. Machined of C932 bronze, the bearing sleeve consists of a single piece (the housing is the sleeve) and a machined cap housing the thrust plate. The bearing spindle is machined out of steel which is then subjected to a hardening process, but is not polished to the finest grade we could achieve in order for microabrasions to be able to retain oil along the length of the spindle. The tip of the spindle rests on a 8mm Si3N4 ball which is supported by a replacable thrust plate, typically made of Vespel (SP-21). The bearing is mounted in a single piece 6082 aluminium block which mounts to the wooden plinth.
Platter. Two platters, actually, in an effort to reap the benefits of both high and low mass designs. The lower platter is machined out of aluminium (6082), with a diameter of 320mm and a height of 70mm, for an approximate mass of ~15kg. The upper platter is machined from Polyoxymethylene (POM, or more often known by one of its brand names, Delrin). POM has similar vibrational characteristics to vinyl (PVC), and has the added advantages of (1) being easily machinable as opposed to PVC and (2) significantly less toxic when heated up (which is always a plus). Both platters are joined through three conical bronze (C932) couplers, which are tipped with 3mm Si3N4 balls, thus allowing the largest degree of platter/bearing separation I could do apart from an air bearing. The record spindle is also made of C932 bronze and can be replaced to cater for varying record hole diameters.
Drive. Based on a previously published project on DIYAudio, the drive centers around a readily available BLDC motor, driven by three individual phases courtesy of a DDS generator and 3 channels of Class D amplification. Speed monitoring and correction is done via a closed feedback loop, implemented through an Arduino Nano. In the vain of sharing, and thankful for the BLDC drive project being published, I have open sourced the actual source code (and the associated PCB) of the speed monitoring section over on the turntables GitHub repository. Power is transferred via a POM pulley and a compliant square section belt (2mm square). All electronics reside in a separate box, the form of which immitates the turntables plinth. Connections to the turntable are via Neutrik connectors (Ethercon, XLR).
The speed correction algorithm is based on parameters devised by research and experimentation. Full running speed is available approximately 4 seconds from the stop position, and rotation correction is sensitive to RPM changes of ~0.001 due to sensor limitations. Control is exerted through a wired remote control, machined from aluminium (6061) and POM, housing a small OLED display to show current RPM and additional information, as well as two pushbuttons to handle multiple operations programmed with the Arduino code.
Further details about how the remote works, and what different button combinations yield, can be found here.
Tonearms
The plinth was designed to support up to three tonearms. When the turntable was first built, two were mounted.
Tonearm #1
Called tân, Welsh for fire. Took the lazy way out with naming once the turntable got its name. It was just easy.
The tonearm implements a stabilized constrained unipivot principle, which has been around for a while. I believe as early as the SpJ La Luce tonearm, if not earlier. This has, in recent times, been successfully copied (in one form or another) to a number of tonearms including the Continuum Cobra, the Durand Telos, the VPI 3D (dual pivot modification) etc. Although there is still a single principle pivot point, the tonearm takes advantage of a secondary pivot, which is typically different in type, in order to facilitate stabilization of said tonearm during cueing and tracking.
The unipivot bearing is atop a bronze (C932) spindle, in the form of a kinematic bearing arrangement built up of three Si3N4 3mm ceramic balls, and a pointed POM pivot. The tonearm tube is aluminium (6061), damped with POM sections, and untreated sheep wool. To further stabilize the tonearm, three separate counterweights are implemented - (1) a fixed one concentrating mass around the pivot point, made of aluminium, bronze and PTFE, (2) a main one made of bronze and PTFE, and (3) an auxilliary fine weight (bronze) with a range of adjustment of 0.2 grams.
VTA adjustments are available during tonearm playback, and have been designed to avoid disturbing the rigidity of the tonearm. The spindle moves up and down in a PTFE sleeve, facilitated by a fine threaded bronze screw on the outside of the tonearm base. Once proper VTA is achived, an internal locking screw prevents misalignment.
Azimuth adjustments are available during tonearm playback, and are facilitated by the secondary pivot. This, in turn, is composed of an elliptical sliding surface, which is 3D printed, using a specific filament from Igus (Igus Iglide) designed for printing bearing surfaces, and a bronze spindle which touches on the very thin ridge of the sliding surface, thus providing for (1) tonearm stabilization, (2) progressive antiskating, and (3) the basics of the azimuth adjustment mechanism. Similar to the VTA adjustment mechanism, settings is through a fine threaded bronze screw which rotates the tonearm tube and can be locked via an internal set screw to prevent misalignment.
Tonearm parameters:
Conversion to SME 3012. A tonearm which started life as a SME 3009 S2 Improved (removable headshell). I changed the tonearm tube and end stub with OEM 3012 parts, and then machined out of bronze (C932) a full set of replacement weights. Additionally, a 10mm bronze spacer to enhance rigidity and make the height adjusment more usable, and a bronze knife edge bearing.
Took the advantage and replaced the ball races in the pillar with SKF ceramic ball bearings.
Damped with sheep wool and rewired using silk isolated copper litz wire. Additionally, machined a custom elliptical piece to house a standard DIN connector instead of the typical RCA and SME connectors.
The tonearm is typically used with a Ortofon SPU #1 E, which yields further data:
An integral part of the turntable, a mass loaded affair built of beech and maple, with an internal metal skeleton built of damped aluminium tubes (6082). With general dimensions of 700mm (width), 500mm (depth) and 700mm (height), it rests on hardened steel cones tipped with 12mm Si3N4 ceramic balls. The rack is built as a single piece and cannot be modified nor dismantled unless destroyed.
Shelfing is built up of natural white marble, a type indigenous to my home country, polished on 5 sides and abrasive on the bottom side where it mates with a combination of cork, rubber and Sorbothane to control vibrational spread.
With the above, the first phase of development of dŵr concluded. It has brought many hours of pure musical enjoyment, but as it was built on a strict project management schedule (to reign me in from a plethora of ideas) it has since undergone a series of under-the-hood modifications.
To those of you who reached the end of this post, I salute you.
I shall wait to see if more details are wanted before I proceed with posting about what is current with the turntable.
Turntable
So it stuck.
Tonearms
Tonearm #1
Tonearm parameters:
- Effective length: 310mm;
- Effective mass: 13.5 grams;
- Range of VTA adjusment (at the pivot point): ± 10mm;
- Cartridge range: 5-25 grams.
- Horizontal resonant frequency: 9Hz;
- Vertical resonant frequency: 10Hz.
- Vertical resonant frequency: 12Hz.
