Weary travellers, we hare reached the current point in time, and the completion of the rim drive.
Introduction
Perhaps the biggest appeal to analogue reproduction to me is quite the established dichotomy between the nature of the reproductive apparatuses and the material itself. A thing which is arguably archaic in the digital age, such as vinyl reproduction, can pretty much always be improved and adapted via investments to new appreaches, especially modern technologies and material combinations.
And it is not as if no desires for disruptions in the vinyl space had ever come to pass (see ELP). But the thing that really fascinated me (and still does!) is the clinging to somewhat archaic and apparently worse methods of reproduction such as rim drives. Users who have had experiences with rim drive seem to swear at the
rhythmic excellence of said approachs, and the prices of the various idler equipped turntables seem to be on a steady upward trend.
How would I ever be able to live with myself if I didn't check?
Execution
Little imagination is needed to understand why idler drives are not more popular with typical turntable manufacturers, and why most designers
(yours truly included - would humbly add himself to that group) stick to a belt drive:
- Ability to use a low (or lower) powered motor;
- No need for an elaborate suspension laden motor mount, and robust motor bearings;
- Belt inferred soft link has the ability to mask a great deal of auditory artifacts the motor may produce; and ultimately,
- Belt drives are cheaper.
What then, prey tell, would one need for a proper rim drive? Well,
I would say:
- Precisely machined moving surfaces to achieve rotational stability;
- Powerful (rather more at that) motor which can also withstand greater than typical radial loads;
- Way to ensure continuously applied pressure of the friction wheel (idler wheel); and,
- Solid vibration control.
And were is
dŵr in this? Luckily, machining already adheres to a strict tolerance (#1), the BLDC motor utilizes sealed ball bearings with a solid radial load bearing capacity (#2), can rely on its mass and solidity to take the place of a precise mechanical apparatus to apply constant pressure (#3) and has been known to be able to soak up a few vibrations here and there (#4). Nothing then prevents me from trying, apart from desire (which is always there) and time to do it (look up history of the year 2020).
Slight twist in all this is that bolting an idler wheel to the motor spindle would simply not do. Having had a proper bearing already, I would go ahead and do a proper
flywheel and friction wheel (idler) combination. I've already used the flywheel effect with the turntable platter, and wanted to see if I had already reached the
"too much of a good thing" point in the build.
When in pieces, nothing spectacular about the flywheel assembly.
Earlier readers of this thread may recognize dŵr's old bearing. Why waste a good thing, right? Machined out of C932 bronze, hardened steel spindle, Vespel SP-21 thrust plate and a 8mm diameter ceramic ball (Si3N4, G5). Base of the flywheel assembly machined out of aluminium (6082), the material of choice for the flywheel itself. External diameter at exactly 120 milimeters, which brings us down to ~2.6kg of movable mass for the flywheel to take advantage of increased moment of inertia.
Putting the bearing together with the base makes for a more compact structure.
Which only leaves topping off with the flywheen and installing the butyl rubber precision o-ring.
Finally moved to its proper working position.
Principle
I have been lucky that with sheer mass and brute force could avoid designing and implementing a precise mechanical assembly to exert continued pressure between the idler and the platter. The flywheel (with the integrated rim wheel / idler) is driven by a square section belt, similar to the Thorens TD-124 approach, allowing for an additional isolation level. Speed regulation and monitoring courtesy of the algorithm described earlier in this thread.
Once a new pulley was in place, switched the order of motor phase supplies (for a direction swap) and let the motor run for some time to account for the changes in the drive ratio.
Measurements
I could go on for days writing on the topic with varied success, but as
proof is in the pudding, we should check what a few measurements show.
Speed stability. In a similar vain to the measurements described earlier when swapping motor pods, I collected data from 160 individual data points and tried to establish the variance of speed stability. Note that all measurements take in account belt and rim drives, but (!) in both cases, the flywheel was used.
To start with, W&F for the measurement cycle:
Belt.
Average W&F: 0.0062%
Worst W&F: 0.0121%
Median W&F: 0.0065%
According to the NAB specification, worst allowable W&F value for reproduction purposes is 0.1%. Well, even in the worst case scenario, this turntable, when belt driven, exceeds that specification by ~8х (8 times), and at average, exceeds it by ~16х (16 times).
Rim.
Average W&F: 0.0081%
Worst W&F: 0.0164%
Median W&F: 0.0079%
Somewhat worse numbers. By how much though? Again, according to the NAB specification, worst allowable W&F value for reproduction purposes is 0.1%. This turntable, when rim driven, in the worst case scenario, exceeds that specification by ~6х (6 times), and at average, exceeds it by ~12х (12 times).
When plotted using a standard
radar / polar diagram, the following is shown.
Rim drive clearly fluctuates more, but in no case was the measured speed below 33.32 rpm or above 33.34 rpm, bringing up the total variance to ± 0.02% in the worst case scenario (which still, even at that point, exactly 5 times betters the declared NAB specification).
(*) OK, I promise to stop mentioning NAB further.
Vibrational characteristics. As with previous approaches, I utilized an iOS application which reads the values off of internal sensors, and compared the effects of the belt drive and the directly coupled rim drive, precicely at the level of the reproductive surface of the turntable.
The result of using a flywheel and a two belts (pulley to flywheel, flywheen to platter) is easily the best vibrational state this turntable has ever seen.
At both graphs, the X and Y axes show the standard resonant frequency peak at 0.56Hz, which relates to the 33.(3) rpm rotation of the platter. Additionally, both graphs are relatively complementary in the area below 1Hz. Additionally, the belt drive's resonant peak on the Z axix is 0.049Hz - let us say - sufficiently below the audible area.
Rim drive, on the other hand, shows a higher resonant peak on the Z axis, as well as additional noticeable peaks on the X and Y axes in the area above 10Hz. I believe that the principal reason for those peaks are the imperfections in the butyl ring used as the mating surface between the idler and the platter. To confirm this, a pair of precision molds for silicon o-rings are currently en route. What is further interesting are the grouped peaks on the Z axes between 30Hz and 45Hz, which may turn out to be quite audible.
Reproduction. Applying the same methodology put in place during the
skating force influence research, I recorded a reproduction of a 300Hz tone, processed the recording and plotted the FFT spectrum, based on which I gathered the values for the first 20 harmonics.
Belt.
THD+N: 0.4601% (-46.74dB) (-53.79dBA)
Rim.
THD+N: 0.5611% (-45.02dB) (-52.07dBA)
As expected, total distortion figures are worse for the rim drive. But what does it look like?
Doesn't seem like one is losing nor gaining much between the drives now, does it?
Sound
Ultimately, what does it sound like?
Well, this may very well be me transitioning to middle-age audiophoolery, but I do understand why people like rim drives, no matter the implementation (unless it is faulty, that is). There is a perceived immediacy to music at a very little cost to final transparency and detail, but that only (to me, in my system) enriches the enjoyment in music. Detail freaks would probably kick me and this turntable out of their rooms, but then again, that is the beauty of this hobby -
they do not have to listen to my system.
Lower and mid bass shows a perceived increase in richness and volume, but also in clarity, easily heard during reproduction of older ECM productions (I am looking at you, Lester Bowie). I would be amiss, however, if not noting that at this level of reproduction, the differences may not be worth to many as they may, at many cases, be on the level of scientific curiosity.
Still it was worth it to me, and stays in the system until further notice.
(**) Of course, I can now easily switch between belt and rim drive by (1) moving the flywheen 20mm to the left, (2) fitting a belt and (3) flipping a switch, so it is not like I cannot choose based on the current mood.
