Your welcome Joe, no crapping taken
Matt, DA11 spec:
SPECIFICATIONS:
THD+N at max volume (volume = 56) – typical, 0.0008% FS, maximum 0.0013% FS
Test conditions: 20Hz – 20KHz, -3dBFS sine wave, 22-22KHz BW
At all possible settings and switch combinations. This also applies to operating the DA11 with the
included XLR to RCA adapters.
Dynamic Range: -112dB typical, -110 dB minimum
Test conditions: Non weighted
Drive Capability:
24dBu Balanced XLR output into 1K ohms at Volume = 56 or lower
21dBu Balanced XLR output into 600 ohms at Volume = 53 or lower
18dBu Unbalanced XLR output into 600 ohms at Volume = 56 or lower
18dBu Headphone into 100 ohms at Volume = 56 or lower *
18dBu Headphone into 50 ohms at Volume = 50 or lower *
* PLEASE NOTE: Do not use “earbuds” or any other type of headphones designed for use with
portable battery-powered devices such as an MP3 player. The DA11 is not designed to work with
this type of headphone. The headphone output is capable of much higher levels than a batterypowered
device in order to properly drive typical HiFi headphones. Damage may occur to the
portable device headphones if they are connected with the DA11 Volume control set to a higher
setting.
Volume Control Precision:
Integral linearity (deviation from straight line) – better than 0.1dB
Differential linearity (step size) – better than 0.08dB
AC Power:
Voltage 90-264 VAC, Frequency 40-63Hz,
Typical Current usage: 0.1A
Fuse Rating 2.5A “Time Delay” *
*Subject to change! Please always check the rating on the fuse and the one printed next to the
fuse holder on the power supply PC board before replacement. Replace the fuse ONLY with a
fuse of the same rating. If you have any questions, contact:
[email protected]
Please Note: The DA11 automatically adjusts to AC power inputs in the range of 90 to 264 Volts
AC and line frequencies between 47 and 63 Hertz. There are no settings to change.
Dimensions:
8”w x 1.75”h x 10.75” d (including front panel switches and rear panel connectors)
Weight:
Less than 5lbs, 6 lbs shipping weight
