If you can send me that cable, I will pay for postage, I will attach it to one of the Grimm LS1 loudspeakers, I will acoustically measure, and then swop back to its stock cable and remeasure,I won't move the microphone or adjust volume in between measurements.
Any difference in bass should be immediately evident.
Keith.
Wouldn't it be a better idea to measure an amplifier or cd player's reaction to such a cable, i would have thought this would show if the cable itself is having an effect on the measurements of the piece of equipment in question,for example it's ability to deal with incoming RFI onto the mains supply, which, in the end is what a cable such as this is intended to do, measure this instead, see if it changes after the cable is fitted as was the case in the ASA request of the Russ Andrews case, the lab did measure differences & recorded them.so i don't see why you wouldn't if you carried out a similar test, or anyone else here with the correct equipment & knowhow for that matter, simply repeat the test a few times for a satisfactory result.
It seems a fair request as most here who hear differences have carried out what they are capable of doing in this area by listening, be it blind or sighted so maybe it's the turn of the non believer so to speak to step up rather than keep banging out the old don't need to listen so i won't excuse.
I will gladly post my Kimber Yello cable & home made belden to anyone who can guarantee a non prejudiced test, happy to do this, just say the word.
I suppose the only problem i forsee is if the reults show a change, this will then be questioned as to if it is large enough to make a change to sound, this is another area which unfortunatley would need a specialist in brain function & perceptability & how the changes found would be perceived by our ears & brains so for now i think the only thing needed is a test to show if the cable does as it says on the tin, the rest is for someone else to sort out but it would at least show if they work or not as intended, ie, remove some rfi entering the equipment. How the item in question then deals with this would, i imagine, be down to the individual piece of equipment & i think there may lie the problem.
The 2 cables i would supply, after some checking around, seem to be the two companies that most people use when using this type of cable, belden for home made & kimber for ready made so a good balance i feel. Also, both cables are made up quite differently. Quite a few ready made also use the belden in question underneath a sheath of choice for this particular company but basically the same cable i have.
Both cables are cheap, basic, non fancy cables so a good choice i feel.
The test would need to be carried out on more than one item, including a cd player & amp & including at least one budget item in both camps as with my Rega brio 2000 amp & planet 2000 cd or similar, all tests would need repeating several times.
So if anyone wants to step up, pm me & i'll post them out. UK only mind. Keep them as long at it needs & post them back.
i Have only one request, both cables are kept in the condition i have become accustomed, neither cable is dismantled & the Russ Andrews seal over the plug screw is kept in place.
