TheDecameron
Unicorns fart glitter.
I assumed he upgraded from a valhalla to the Mose- thats the comparison Im curious about....
Hi
I got a Mose/Hercules and a 110v motor about month and a 1/2 ago for my Thorens TD150 was using a 16v motor with a Pro-ject SpeedBox II . Big improvement big drop in noise floor deeper bass clearer highs more detail what a great upgrade and Edmund is a great to deal with . Also if you a Thorens,Ariston,AR or oter turntable you should look in to getting a Mose/Hercules you will love as I do.
Robert
croak,
You are right the thorens motor is 16pole so 50Hz it runs 375 rpm@33 1/3 But the motor is quiet with wall power but with the Mose/Hercules super quiet. Going a to 24pole would be hard what size pulley? If you get a Linn motor the pulley is 21mm for 50Hz I think but the thorens sub platter is not the same size as the Linn so speed wouldn't be right.
And how for cost a Linn 50Hz motor $180 plus making a pulley it's to much my Thorens TD150/Sole Sub-Chassis/Mose+Hercules/AudioQuest PT7 and Linn springs Bolts rubber and so on, I very happy with all the mods and now I can stop modify.
Would be interested in feedback from owners of a Hercules power supply; those who've had the unit for a while. Thanks in advance.
Had my Linn LP 12 since 1978 and the only thing left of the original is the outer platter! Right had the Valhalla fitted when it came out in early 80's and then bought a lingo mk1 when they came out in early 90's. Had that for some 15 years and sold it on flea bay for nearly what i paid for it. Valhalla to lingo was an improvement. Then some 5 years ago i bought an Aro and sold my ittok massive improvement, followed quickly with an olive armeggedon huge improvement. Maybe the Aro needs the armeggdon i don't know.
Regards,
Martin
Hi, all.
Several people say that fitting the Mose is easy (I already have a Hercules Gold fitted internally by a dealer), but I can't really see how given that I believe you can only access the LP12 circuitry from underneath and clearly you can't just tip the LP12 on its side! Don't you need a special open table to get into the LP12 from underneath? Won't the suspension then have to be re-set? Any thoughts?
What are you doing to your motors? I had one fail on my STD almost new and since then unchanged in 35 yearsMotor has been replaced 3 times, plinth i'm on my 3rd as ...
Mine is now on it's way from Hong Kong. I will post a comparison versus a MK1 Lingo next week.
Regards
CJ
Was this comparison ever done, it would be great to hear how the Mose compared to the MK1 Lingo
Where can one buy the Mose box and associated wiring for the herc II?
