Hi Pinkfishers,
I thought I would start a thread for anyone interested in my latest build.
After finishing some big heritage Klipsch using my originals as a source for a direct copy I went about looking for another project and ran across a few threads on Westminsters so started drawing up a battle plan.
Forty sheets of A1 tracing paper later I had my plans fine tuned and a cut list-
3 sheets of 26mm and 4 sheets of 18mm 8x4!
It arrived and I began cutting to size with the Felder table saw.A day later all home too my studio for veneering (workshop was a little too cold for the veneer glue).
Here are some veneered panels.
http://www.flickr.com/photos/48329457@N06/6836831799/in/set-72157629218661725
http://www.flickr.com/photos/48329457@N06/6836794537/in/set-72157629218661725
I did not want anything too flashy for the veneer so went with a good quality crown cut oak and went about researching the finishing products from oils to waxes too water based polys and came across Osmo polyx, a natural oil/wax that dries very hard so very protective. It will have a satin finish when polished. I am not really a fan of highly polished speakers so this was perfect. It was not cheap though.
After a lot of vacuum pressing veneer-a lot of the panels need to be veneered on both sides as the back loaded horn design meant they would be visable without the grills, even 6mm of overlap was done-I just veneered the entire side to keep measurement absolutely plumb.
http://www.flickr.com/photos/48329457@N06/6836859511/in/set-72157629218661725
Here are the Drive units-3836's that will be converted to 3839's by the ever helpful Lockwood.
http://www.flickr.com/photos/48329457@N06/6836835599/in/set-72157629218661725
http://www.flickr.com/photos/48329457@N06/6836869885/in/set-72157629218661725
I want these speakers to be built with no expense spared so all internal bracing is solid oak baton with brass countersunk screws. Accurate measurements needed for mm perfect joins.
http://www.flickr.com/photos/48329457@N06/6836781927/in/set-72157629218661725
http://www.flickr.com/photos/48329457@N06/6836854153/in/set-72157629218661725
http://www.flickr.com/photos/48329457@N06/6836770083/in/set-72157629218661725
http://www.flickr.com/photos/48329457@N06/6836773979/in/set-72157629218661725
http://www.flickr.com/photos/48329457@N06/6836799927/in/set-72157629218661725
Here is the top bottom and internal sides dry fitted-not small-
http://www.flickr.com/photos/48329457@N06/6836864577/in/set-72157629218661725
After more researched I asked Nick Gorham to build the external cross overs so built solid oak boxes with 6mm brass tops...they are with Nick at the moment so will post some pics on there return.
I have put one of two coats of polyx oil on to all external panels.
Tops-
http://www.flickr.com/photos/48329457@N06/6836826761/in/set-72157629218661725
With and without finish-
http://www.flickr.com/photos/48329457@N06/6836819037/in/set-72157629218661725
Lots of parts-
So this is where I am at present, I will continue to post as i build. I hope to have all panels back in the workshop on Saturday to begin domino jointing and routing the driver ports which could be tricky as they have a bevel at about 40 degrees and are not perfectly circular.
Thanks for looking Si.
Tops-
Lots of parts-
