I found the CA decks looked very bling but sounded quite poor. Thin and a bit shrill. I consider them to the Bang and Olafson of high end decks, really more appealing to lifestylers
The michell gyrodeck doesn't do anything badly but everything is just a bit below average especially solidity and timing. The orbe is better as it should be but isn't outstanding in any respect. No fanboi defensiveness from anyone please. This is just my opinion
http://app.audiogon.com/listings/tu...tone-arm-as-low-price-2014-04-06-analog-92808
On at $9k which would translate to £5k with a bit of bargaining. People have preferred this setup even to an SME30
Stick a decent cheap cartridge like a £200 ortofon on for the time being then save for the brinkmann emt
Another for under £4k sans arm
http://app.audiogon.com/listings/tu...io-bardo-2014-04-07-analog-92025-escondido-ca
A used SME 10 would be within your budget but its the weak deck of the line up with serious short comings. If you want a tidy over civilised sound and just listen to classical then go for it otherwise avoid. Plenty here would disagree I am sure
