Anyone done a comparo with MDAC?
Hopefully this is a case of him using an internet image of the inside (or Pro-Ject provided marketing) so that we didn't have to open up his review unit.
Hopefully these (pink caps) are not out in the wild...
Are you asking about John's original Audiolab MDAC or his current DIY project?
i meant the original Audiolab MDAC.
Let's hope. That strange filter result was very real though. I've alerted someone at Pro-Ject, though I suspect they knew already.
I thought his findings were in line with Jussi's published a while ago - Optimal Transient's filter was not best? And linear phase + fast rolloff was the best he measured.
Yes it's suboptimal. So-to-speak. ;-)
It is something that should have been noticed at the factory during final testing though.
Here is the first S2 DAC death I've read about so far that doesn't have anything to do with breaking the microUSB connector (which I've had happened with other DACs too):
I have a problem with windows mixer volume control. I'm able to control volume via windows mixer when I'm listening music in Foobar with wasapi. But only when S2 is set as default device. I think wasapi is here to direct communication with sound device to bypass win mixer. One month ago it was OK. When I set S2 as default win volume didn't contol foobar, but now yes.
Does anyone have the same problem? How to solve it?
One more question: some information about "Lakewest" build and level meters from this link? https://pinkfishmedia.net/forum/threads/pro-ject-pre-box-s2-digital-dac.201691/page-11#post-3236039
What does ASIO do that WASAPI doesn't do?
What does Tidal do - it's clearly passing a bit-perfect stream (MQA flag). What driver does it use to achieve bit-perfect? Does it install some driver along with the application?
Hmm. Thanks. I guess you must have installed WASAPI and ASIO, and Qobuz is recognising this. Tidal just gets on with it, and still manages to achieve bit-perfect (according to to the MQA flag on BBS2D). I guess it's using DirectSound - if I guess right, then DirectSound must be capable of bit-perfect.
(I took a screenshot but cannot figure out how to include it. I would rather spend time understanding how to use my PBS2D than how to use pinkfishmedia.)
If you don't bypass system audio you're not getting the full benefit of using an external DAC to improve performance. You want to send a bit perfect signal to the DAC, and then let the DAC control volume. In your example above that means don't use DirectSound, use WASAPI and fixed volume. But there is an ASIO driver designed for this DAC. Any reason you are not using it? The driver control panel includes a software volume control, and using that would be more acceptable if you must, but the goal is to send a fixed signal to the DAC and control the volume from there.
It doesn't matter if I use Wasapi or ASIO - same problem. Win volume control still working. I don't want to use any type of software volume control in windows. Direct sound worked some time ago with no problem. But now, on the same version of Foobar, firmware, driver and without change any settings it not work correctly.
