I presume you refer to the original Elicit ?
I guess I preferred the Rega to the naim
Not the original Elicit. The Elicit Mk2. The Elicit-R is the Mk3.
Thank you for the insight. I will go with the 21. If you would not mind sharing what the differences of presentation and sonic signature of old exposure vs new exposure are. In the US Exposure gets very little discussion on boards. I did find someone using 3012s preamp and Dual 4 reg and he said it worked together really well bit did really go into any detail.
I've just bought an Exposure 18 power amplifier, can I use it with my Naim Nac 72?
I have teddycap, and cable. Thanks.
yeah I ran the 17 and 18 mono for awhile. Sadly it was not re-capped and I think they really need to be. The Dual 4 reg is recapped and so much more grip, slam/bass control and a much bigger sound stage. I really don't ever think I heard the 18 mono as they are capable of performing. My mistake as they are long gone now.
So how's the demos coming on Robby?
Bit of old Exposure history here albeit with new caps (the transformer is original):
I am using an Exposure 2010S2D with naim SBLs and Naca5 after going up and down the Naim chain a couple of times and I must say I like it better than all Naim integrated amps.
Warmer and softer sound with better bass for less cost.
Interesting. When I spoke to Tony at Exposure, he said that my 18 wouldn't need to be recapped unless it had a loss of bass.
Thanks for the update. Interesting that you find the Exposure 2010S2-D to sound better than the Naim Supernait 2.
Sometimes "warmer" or "softer" can be interpreted differently since it is difficult to accurately describe the real differences that we hear with our ears.
