I would certainly welcome a balanced AV bypass in my system, even if this means having 2 dangling leads for balanced inputs on the back of the MDAC2. My L3 MDAC has single ended bypass, which is a very good start, but a compromise as my whole system runs balanced.
ok...I have just paid the 1st 100 pounds and added my name on wiki list but I had no reply from anyone.
Let's hope for the best![]()
Hi,
It's been a while since I've last been on the forum. Where are we in regards to MDAC 2?
Thanks.
David
how to get a mpax supply?
I draw the line at soldering though, sorry I'm just not practical enough and I know it would look bad by the time I will have covered it in solder.
Roksan Caspian Mk1 power amp spotted for £400, no balanced inputs though. Any good?Thought the integrated mk2 was pretty good when I heard it last year. Never heard this one though.
Carloica,
Thank you for your payment received earlier this morning, Renata will reply shortly with confirmation and any questions.
Thank you John...When do you expect are you going to be ready to upgrade our mdacs?
Guess we will include an option for "Dangling leads XLR Balanced AV Bypass" at at an additional cost ("at cost" for those "community supporting" the MDAC2 project development - Oh and including those who own a Toy or Fusion upgraded unit)![]()
The Mdac 2 is due spring 2014. Note it is a board swap DIY or send to John for swapping.
I'm already a month behind with the MDAC project (Analogue stage PCB should have been released early November - I'm issuing it in the coming days) - so its looking like April at this moment... teh Delay has resulted in a better product - especially for headphone users with its high power output stage.
Hi, sry if the same question has been posted before.
Yesterday when I tried to turn on my m-dac, something strange happened. The usual "click" sound came, but then nothing happened, as in that the display remained black. Then after about 35 secs the display says "LAKE WEST", but shows nothing else and doesn't respond to anything. I tried several times, but could not get it to boot properly. The unit was not warm.
I left it off until this morning, and today it turned on OK on the first try. I then swithced it off again to check the firmware version, but then the same problem occured and after this I've not been able to start it (because of this I don't remember the firmware version, but at least i remember I upgraded it to get the auto dimming of the display. This is also the firmware that it's been working fine with for many months).
Anyone have an idea what might cause this, and how it can be fixed?
