therixonator
ManMan,
The AV bypass of the MDAC2 (or MPAX) is designed so that you could include a MDAC2 between a preamplifier (stereo preamp or preamp section of an AV receiver, both of which providevolume control) and a two channel amplifier. The idea being that the MDAC can be bypassed with other analog (AV) sources, while taking over, including for volume control functions- for two channel digital playback.
Adding a pre amp (passive or not) between the MDAC2 and an amp defeats the purpose of the AV bypass but there should be no need for a preamplifer if you already have an AV receiver
Eiffel, does the pre amp/av receiver that you feed into the mdac av bypass need to have some kind of 2 channel output, pre outs or something like that, to work? I looked into doing something similar with plugging my av receiver into my stereo amp so that I could use my best speakers for music and movies. My av receiver didn't have pre outs though so I had to go for a speaker switch instead. So in short, with the av bypass option being available, I guess I still have to go with the speaker switch route now unless I change my av receiver?
