For me... not much, I rarely use headphones, but, as the MDAC is the best headphone amp I've used, it would be reassuring if it was the best possible.
I know I keep going on about it, but a volume controlled analogue path would be my nirvana...
When I click on the link, all I get is "access denied".
Can anyone help?
David
Hi John and all,
Would the MDAC 2 digital pre output have a higher output of say,.. up to 5V.
Perhaps we could have a 3 gain select (lo, med, hi) on MDAC 2 ? This would accommodate those low gain power amps.
Morning John,
I've just PM'ed you. Paid my due's for the new MDAC, but forgot to tell you me PFM ID. Hopefully, it all makes sense.
Sorry for the hassle.
Dear John,
in July you posted:
"Been thinking about it - I'm going to try to design-in the option to add an Analogue Pre-amplifier board at a later date to the MDAC2... maybe with two pairs of Analogue input with with level control - RCA only inputs due to rear panel space...
The board can be added later - I'll not have time to complete the design before the MDAC2 Mainboard released..."
I wonder if this option is still in your mind. If possible it might be great for all the vinyl lovers around us (no extra preamp needed...).
In any case, thank you so much for discussing all this stuff with the crowd...
Jansen
...with the sliding bias circuit modulating the standing current if required
The most likely route we will take is to have the AV Bypass RCA's mounted on a separate PCB which is mounted above the MDAC2 mainboard - this can be 'User' replaced later with an Analogue input board with Level control - or even an ADC board... who knows what the future will bring
Fascinating. How does this configuration "know" when the bias must be adjusted up to real class A? Insertion of a plug into the headphone socket? I can see that you could use the secondary contacts on a jack to achieve that, but most other connectors don't offer that facility.
Does a meat holder come with this grill?*This allows the use of 30 Ohms balanced Headphones with a resultant 6Vrms - in ClassA!!! - hence making the MDAC2 a very decent headphone amplifier!
Great combination! Listening via speakers without a dedicated power amp while enjoying the warm air around the MDAC2 (and saving money on a regular heater), now that's something!Considering the Winter months approach - I'm insuring no cold spots on the lab bench...
The real dissipation (heat output) will be low as the peak energy of Music is low... 99.9% of the time the Bias will be idling at the nominal 50mA... Could you image how loud 6Vrms would be on a pair of headphones!
In for low listening levels you could connect a pair of speakers directly to the MDAC2 output.
