Hi John,
Will you be at the Bristol show this yearwith the MIMP and MPAX..? I was looking at the list of exhibitors but I couldn see Lakewest.
H
Again sorry to hear about you issue - it might be a PSU related, if your by any chance located in CZ then I can take a look at your unit..
John
My Mdac has arrived for exactly a week and has been using its headphone amp on and off since then, I've updated fw to v08 and using minimum phase filter as I found it the only filter to avoid the glare of violin, I wonder anyone here would share his view on this filter? Whether it is good or bad.
Is there any relationship with a current discussion i've missed ?Time to swap for something less sharp in the treble.
Here they are compared with AKG 701's (red line)
I use this filter for precisely the same reason as you: to try to calm down the almost unbearably bright violins. At first I thought it was my system that was too bright, but I get the same issue when I use headphones (Grado GS1000i). It's the only problem I have with the otherwise superb MDAC, and I'm hoping the much-mentioned and much-anticipated MPAX will improve things.
When I'm not listening to violin-heavy recordings, I revert to OT XD (with software A0.06).
If anyone has any recommendations how to ameliorate the situation before the MPAX reaches production (it is no longer so high on John's "forthcoming" list) , they would be gratefully received.
Excuse me, i've missed a slice of this previous msg !
I apologize
I'm wondering: has anyone compared the sound on RCA vs XLR on the M-DAC?
I'm running on RCA, but thinking about adding a high quality XLR input to my power amp. Wondering if it is worth trying. The amp is of course not balanced.
The Volume control function in the MDAC is performed by the ESS DAC - we have no external access to this Data to route an attenuated datastream to the MDAC's DOTX outputs.
As the TDAC has an FPGA DSP we could add this feature to the TDAC at a later date.
