I have raised this on another post
http://www.pinkfishmedia.net/forum/showthread.php?p=1896383#post1896383. But hoping John or other expert on here might have some thoughts. I have a SBT clone (a joggler running linux with squeezeplayer running on it) see
http://www.jogglerwiki.com/forum/viewtopic.php?f=2&t=740 for some info. A number of very clever guys have not only got squeezeplayer to work pretty flawlessly, but also port triode 24/96 USB cleverness too.
All is working very well. I have the joggler hooked up to my MDAC via USB and 24/96 is working well, also have tried bit perfect and it passes. But I have noticed a noise on the line, that is best described as a mid/high freq whine. only audible with highish amp gain. volume on the Squeezeplayer volume slider or the MDAC volume makes no difference. In fact you can set the volume to 0 and the interference is still there. Now it starts to get interesting, if you switch the MDAC to a different input, eg coax or optical the noise is still there (at this point I started fearing it was an MDAC fault). But when I unplug the USB the interference disappears and silence ensues.
Some have suggested USB isolators. But I am interested based on this description whether the symptoms are likely to be solved with such a device?
