Hi James,
Which dealer did you buy the MDAC from? did the unit appear freshly sealed? While statistically possible you could have a second duff MDAC in a row, its very very unlucky.
Where the units B-Grade stock?
You could try the MDAC in a different room, just in case something is blocking the IR transmission - also is the Mini Din power cable correctly inserted, with no bent pins?
While the handset can be seen to be transmitting it cannot be guaranteed that its transmitting the correct codes - so it could be the handset or the MDAC itself...
Try twisting the power cable on the rear very gently...
Hello John,
The supplier of my M-DAC is 'SuperFi UK' (http://www.superfi.co.uk/) - the unit is suppose to be brand new, not opened boxed or display etc. Although now that you mention it I found it strange how this unit had one slightly scuffed rubber foot and no plastic protection sleeve on the display, my first one did. The box was completely sealed with Audiolab tape though so I expect it's brand new.
I have just tried the unit in 2 separate rooms which both have the same result with no response from the remote control. The power is inserted correctly and has 9 perfectly straight pins. I just tried twisting the power cable on the rear slightly and still nothing.
Thanks for the reply, the help is really appreciated.
Kind Regards,
James P.
