Hi jmbulg,
Here's the Beta Software if you want to try before the full "Official" release. This opens the Optical 2 input to maxim DPLL bandwidth which should resolve your Airplay Express drop-outs.
Please understand that this is NOT an official release so “at your own risk”, although I’ll offer all the support I can.
The updater only works on Windows XP, Windows Vista & Windows 7 (32 Bit Mode).
This is a console version of software update tool for Audiolab M-DAC.
Close all audio applications before proceeding with the update.
Before running 'update.exe', please make sure the M-DAC is powered on and connected to the computer via USB.
Once finished, turn the M-DAC off and on again to restart with new software.
Download the Beta software from:
http://db.tt/pV5gEOND
1. Extract the files from the Zip folder
2. Insure MDAC is connected to PC via USB - selected to USB input and the MDAC Display indicates "Ready"
3. Insure no other software is operating on the PC (anything that could interrupt the upload process to the MDAC).
4. Run the "Upload.exe" program, within 10 seconds the computer should report a successful upload.
You need to power cycle the MDAC - switch Off the MDAC for 5 seconds and then re-power for the software changes to take effect.
You can Push and hold the MDAC's Volume Knob while powering-up to indicated the software versions.
Old software v0.90 / v0.90
New Software v0.90 / vA.10
John
