Unfortunately I can't select anything on the Rotel (and I want to use this transport - the Oppo was just wheeled in to check the lock-on of MDAC). It was a circa-1991 era CD player, and Bitstream was the latest 'in thing' in DAC design. It's worked perfectly with all DACs (vintage and modern) without any problems at all until MDAC so unfortunately I doubt it's to blame to be honest (I hope!). Stutters/silence at the beginning of tracks aside, it plays really nicely and passes the Audiolab bit-perfect test too. I just hope JohnW will find some cunning way around it with a firmware mod. It's not a huge problem as I mainly use USB and a Mac mini, but I would like to sort the problem out if possible, so it works as intended.
So far both my Rotel and the Oppo have this momentary (only half a second if that) locking-on problem with the very first track with MDAC, and also if skipping to another track, or backwards to another. Bar pressing play on the CD player for the very first time, it's glitch free if playing a disc straight through. It's only if skipping tracks, so must be as JohnW suggested a while back, it's locking-on again from scratch if a track is skipped, and on the very first track played. It needs to lock on and buffer the data perhaps to prevent this.
I'll see if I can find any other transports in the house with a digital out and see if it does it with all of them. I'll be a bit concerned if it does as I'd consider that a bit of a flaw in MDAC if that's the case.
- John
