JemHayward
Mains filters can be an issue with power amps that draw a variable amount of current from the mains, i.e. class A/B or B - the most famous example is Naim, my NAP250 sounded awful with any mains filter I tried. Class A, which is how the majority of line level stuff works, seems to be ok with most mains filters, and my EAR890 valve amp, which is class A, is happy with a simple mains filter. I built a mains distribution box which has one mains lead in and six out in a star earthed "hydra" fashion, and I have a separate mains filter on each output so each device is separated from raw mains by one filter and from other units by two. Its works fine and I can switch my Linn Lingo on and off and it makes no difference to the sound of the system (well, the LP12 slows down...) for the first time ever. I also use screened mains cables and a DC blocker and have two switched circuits using RF switches so I can switch the system on from work, so its warmed up when I get home! A pretty geeky box!
