-i have invested 1270£ into this project, if i get offered a full refund+interest i would probably take it despite needing an ADC.May I suggest designING your own dac
On the matter of measurements, it should be said those of you getting a streamer built in are in for a treat.
I've recently discovered just how much of a PITA USB can be when it comes to getting ultimate sound quality, so the fact you don't have to deal with this is a big big plus.
Infact, I'd go as far as saying its possible some part of the anti-digital brigades complaints about digital audio could be partly due to USB....
Apparently everyone knows what a discrete dac actually means. Great idea to cut through all the years of resdesign and delay by ditching the off the shelf chip. I imagine that will speed things up no end.
Agree 100%, USB was ditched here over a year ago. A huge SQ improvement for any DAC.
And why should anyone's alarm bells start ringing when all the talk turns from the thing whose arrival is imminent to the next thing? Is the design of the ESS dac complete, actually complete, finished and just-give-me-the-SMD-machine-and-we're-off? I worry.To be fair didnt JohnW himself say "v1 will be with ESS silicon" ? With the option later to upgrade to the discrete DAC daughter board when its ready. Which seems sensible as a path.
For those who don't like USB interfaces, the internal interface between the streamer and the MDAC2 will still be via USB! This being said, my experience with USB has been good, including with the MDAC and my SB Touch.
Anyone considered that the USB problem is that the source is sending crap down the USB ?
Maybe we should badger the manufacturers of PC's and NAS's.
but the "fatal" issues is that the I2S interface of the CM3 does not allow the DAC to be "Clock Master"
I doubt the CM3 is "slave" or the DSP is performing ASRC as the BCM SOC cannot support external I2S Audio Master clock. If I'm mistaken (and it be good to know the EXACT implementation) then still it does not get around the 192KHz / DSD limitation of the RPi I2S port.
Also a big factor is "Driverless" audio support which USB allows - I have been so burnt with Beagle-bone and the H3 board in the past.
Since the mdac2 also has an ADC it should be very easy to contstruct an ABX test whereMay I suggest when possible, try to listen to a discrete DAC implementation?
As mentioned earlier in this thread I currently have a discrete DAC and I would fully concur with JohnW's findings when doing comparisons against 'off the shelf' silicon.
Would it be possible to just get it without the external HQ psu? (saves money and i would not need to have an external PSU).
Besides what we have been promised so far with the mdac2 i would also like to have High quality DSP and support for sampling rates above 768KS/s.
Would it be possible to just get it without the external hq psu? (saves money and i would not need to have an external PSU). Besides what we have been promised so far with the mdac2 i would also like to have High quality DSP and support for samplingrates above 768KS/s.
SInce i plan to design speakers i might actually need the fdac too, it's mostly the DSP i am interested in.
I might only need a DSP for the subwofer and if that is the case i can just use minidsp.
A=connect your dac of choice directly to the speakers
B=add the mdac2 to the loop(AD and DA conversion and level matching).
This allows you to test the transparency of the mdac2, it's highly unlikely it wont be transparent 100% of the time. I can construct a test like that once i get the mdac2 and the rest of the system.
