JohnW
pfm member
It's not, but it will be soon
- try reseating the front panel cable
John, can the PMD200 still be a filter option for the Dual ESS based DAC?
Hi John, will it be possible to have the DAC section on a daughter board, so one could buy the ESS version and the discreet version, then just open the case and swap the board?
If so then it would be good to try both, then I could always change between them sometimes if I fancied a change.
I presumed the boards would be interchangeable, will they require different back-plates though?
Do you have any proof there is audible distortion from decent op-amps (blind tests) ? i will take a look and see if i can find anything.They say the same about opamps
It is a pre-requisite for me as I intend to continue to use a CD transport as well as the streamer.
Wow! When you said you were going to finish the MDAC2 for Munich but didn't, I was starting to wonder if the doubters really were right after all. But hearing what you're planning now, I'm starting to get very excited again (and ultimately I have kept the faith - I did buy a streamer board after all).
It seems as though the MDAC2 will have all the advantages of the FDAC now, apart from a single box solution (which I don't really care about) and DSP - and I suspect somebody will come up with a Volumio plug-in for this well before John even starts the FDAC.
I definitely want the PDM200 option, and I'm very excited about the DaCapo Anniversary option (I remember lusting after this beauty back in the day, but I could scarcely afford it then). However, I am very curious about a few things:
1) Is the volume control the same type of digital control the SABRE has (a 32 bit control in 1dB steps)?
2) How would you describe the sonic differences between it and the ESS 9028?
3) If you couldn't fit an ESS 9018-based design in the MDAC case, how on earth will you fit a discreet DAC?
You are writing just about the 200. Some of us bought and send you the 100. Isn't the 100 within your plans?For the discrete DAC we will use the Digital volume control section of the PMD200 - which supports 1dB steps.
Is there a chance that the 9028 Pro will be better than the 9038 mobile version?
We have alot of listening experience now of the ESS9018 & dual ESS9038Q2M's. The newer HyperstreamII ESS9038Q2M sound better then the 1st Gen ESS9018 especially with DSD, but the differences are "small" especially when compared to say changing speakers. For sure its nice to have the improvement, but its diminishing returns.
When we listen to PMD100 / Discrete Dacapo DAC it just killed the ESS Dac's.
Something is not right here, there is 3 possibilitiesThe ESS9018 and ESS9038Q2M have a "House Sound" you can tell they are honed from the same roots - the difference in quality between the discrete DAC & the Dual ESS9038's is so great that I don't believe that there is anychance the 9028Pros will be able to close the chasm.
-the ess design you have developed is flawed, if this is the case you should measure high noise floor, THD or bad frequency response.
-placebo effect due to signed listening tests.
-you are(despite your age) being able to hear a difference in frequency response due to different dac filter, if that is the case the diffetence you hear should vanish at higher sampling rate.
Higher fidelity does not always sound better, i once blindtested 44.1 vs 96 and i preferred the downsampled version 30 of 43 times.
I am pretty sure you could connect 100 mdac2:s(ess version) in series(each converting analog -> digital -> analog) and incert them after your preferred dac and you would still fail ti hear aky difference.
