Sounded worse? how is the ess based dac not transparent? has anyone actually bothered to do blindtesting?Yes, its was a massive surprise to Jarek how Dacapo I designed back in 1991/2 just kill's the ESS based DAC's - so much for the march of progress!
I fear what I'd "feel" if when we listen to the MDAC2 + "Dacapo Anniversary" DAC option it sounded worst then the original design!!! that would not bode well for 25 years of extra knowledge!
Last Night my Transport had a Problem and I switched back to my old Philips Player with TDA1541 and I have to say that it sounds better than MDAC with Transport.You get used to Stuff when listening with it all the Time and the old Player brings back natural,emotional Presentation.
Simon,
Thank you - To IAG's office or the Hotel....
Yawn
giovvanie,
Yes 13.9V is alittle low, really 15V is a good target.
0.65V is dropped by the Input diodes and then add cable losses so 1V is about correct for input voltage drop.
I'm quite close, and would love to meet you both, and see the streamer..
Derek
Hi John
I can increase PSU output voltage to 16 V then M dac will get dead 15 V after the voltage drop . Do you think sound quality will improve ?
I will continue to be unconfortable in this thread until i get my money back or until johnW stops making design desisions based on highly based sighted listening tests. I have invested over 1000£ in this and i am highly dissappinted johnW will spend time making the future iteration worse by adding tubes and changing to a low performance dac chip(resulting in a 24dB loss in dynamic range).
Yes you might be able to hear a differene between dacs at low sampling rates due to different filter settins but listening tests are not suitable for evaluating the performance since the noise in the room, recording, etc is likely to be much higher than the noise from a high performance dac. The limiting factor will probably be the amplifier when you have oppo sonica dac or better.
