Coll, BobL,
As a backup plan if it does prove impossible to fit the loader into the chassis then we would design it into the Detox style case operated by the FDAC (display controls etc) - so just a slim case with slot and eject button - the display / controls would be on the FDAC.
Coll, you could then pop in a 32GB SDcard in the FDAC's rear and transfer your most often listened too CD's into the FDAC directly (The FDAC can insure a bit perfect error free rip) - and save the drives lifetime... with Lossless compression the FDAC can hold 100 or so CD's of your most listened too CD's on a single flash card...
Coll, I'm mindful that the main reason you joined was due to the CD internal loader, so I'll do my very best to squeeze it in...
Hi John
Thanks for your comforting comments.
If the loader is separate which obviously I still hope it is not could you supply all necessary leads to attach it to FDAC so nothing else is needed to get it up and running. I do realise that this would be an extra cost of course.
Unfortunately for me it would have to go on a different shelf in my Hi Fi unit as the shelves are not wide enough.
