Have just bought a 2 month old MDAC, which was sold as working. Display and front panel controls working OK but irrespective of whatever input is used, coax, opto or usb, there is no output, any suggestions?
Not sure what you mean by 0.9 - there's V0.90 (Audiolab) or A08 and A10 (Lakewest builds) - but as far as I'm aware LW 0.9 is not a valid software revision.
You could try reloading say V0.90 firmware to see if this resolves the issue....
Sorry, I meant 0.09
Thats an odd software build - it might be worth trying V0.90 or A08
I still not sure what software revision your unit has installed as 0.09 does not sound like a realise build - I suggest reloading the software.
Please, some time ago somebody offered to send attenuators made by John using Vishay's resistors for a test.
Is it still possible?
Unfortunately can't find that post anymore....
My listening levels are 45-60db down, really wondering how it sounds with them.
I'm just wondering what sort of sound the MDAC 2 will have compared to stock?
Cheers
Rob.
Considerably better (we hope) but not as good as when valves are added to the analogue output stage.
Truly transparent is the general goal.
Yup Transparency is generally the goal! I guess I'm wondering what John/Dominic feel are the weaknesses in the stock MDAC, and if there have been any posts previously that describe them / explain the reasons and fixes.
I guess I should start at the beginning of the first 'MDAC first listen'. thread and read for the next couple of months
That's approaching it back to front. It's not "what's wrong, we've got to fix it". It's "what's the best we can do for the budget". Where "best" means engineering best based on prior experience of designing for audio quality.
ExactlyBTW great sounding DAC the MDAC
it's just made me curious to know what are the sonic differences that you guys are aiming for?
No need to start reading right from the beginning if you're just after reviews of the upgrade: http://www.pinkfishmedia.net/forum/showpost.php?p=2032446&postcount=379 There are several reviews of the benefits of Toy and Fusion upgrades from this point onwards and I think the consensus is a more holographic sound stage.
the Vishays bulk foils did what they do Resolution was notably lifted and sound stage opened up very nicely It retained it tight foot tapping bass with even more clarity, removed a fuzzy hush effecting fine detail resolution was nice sound stage was much wider (although not as wide as the Tyco) but most importantly retaining its Foot tapping abilitys.
