How many resistors are required for a fusion build?
Have just bought a 2 month old MDAC, which was sold as working. Display and front panel controls working OK but irrespective of whatever input is used, coax, opto or usb, there is no output, any suggestions?
No problem with same inputs to another DAC so not a source problem.
Has anyone done any listening tests for Vishay's SMD vs their usual offerings? Does anyone mind humouring me on the cost of Vishay SMDs, I don't feel like digging through the thousands of posts! Thanks in advance.
Have your tried to cycle the power? are the level meters moving to "Music" - if they are and you have no sound, then try cycling the Digital filters.
Dont worry I can repair the unit for free if theirs anything wrong - you would just need to cover the shipping cost.
Is the MDAC receiving a signal? Any response on the level meter? In this case it might be a stucked relay.
No response on the level meters. Does that indicate a stuck relay, if so how do you 'un-stick' it? I assume it requires removing the panels? If I insert a headphone plug into the headphone socket you can hear relays clicking.
The Amps follow the MDAC2 - I can see MDAC2 keeping me busy until the end of the year with production and support.
I'm very keen to launch the amps - I have x5 quad 240's that will be used as donor chassis for the prototype - a few of these units will be launched before for "feedback"![]()
Sprint,
Which Digital input are you using? - how have you connected the MDAC to your digtal source? Its strange that the level meters are not moving.
When you select the input connected to your digital source the MDAC should indicate the sample rate - even when Music is not playing.
If the MDAC displays "unlocked" then there is no Digital signal to the MDAC (if your using Coax or Optical Digital input) - insure you have connected the Coax cable to input 1 or 2 and NOT to the digital output.
By "cycling the power" I mean to Power the MDAC Off wait 5 seconds and then power On again.
JohnW,
Assuming that all options will use the same 2 pcbs, might it be possible for a basic MDAC2 to be upgraded later on? (Personally, I wouldn't risk removing smd components from a crowded board, but cutting a link or two and adding new parts could be feasible.)
I used to be indecisive, but now.......
Hi John
Have taken photo of connections, but can find a way to add/link it to post, but the all connections are correct and to inputs and not the output. I have a seperate coax, opto and usb connections to the MDAC.
All displays are showing 'unlocked' with no movement on level meters and no sample rates displayed on any input.
Coax is from a SBT and usb directly from Vortexbox unit. If I make the same connections to another DAC no problems?
Have tried cycling the power on and off about 30 times to no effect.
Really really odd - it does seem like your unit has a problem, and its not related to the MDAC's "Stock Faults" the Crystal or Relay.
I've not encountered this problem before - so I'm at a loss to suggest a cause - unless the Cable to the front panel has come loose - or been damaged if someones opened the unit and had a poke around inside....
I've had many MDAC's through my hands, and with very few problems... just very odd, my rather cynical side wonders about this units history...
Please Don't worry, I can repair the unit for you for free - you would just need to cover the shipping costs... Unless your near the IAG service in Huntingdon and they could take a quick look...
