say it as it is
do you need this and soft start module as well?
There are also modules from XRK Audio: https://www.etsy.com/ca/listing/932...-protection-gen2?ref=shop_home_active_3&crt=1. These ones don't require a separate transformer, as you can just power them them from your main supply.
Yes, two different issues. Soft start is to limit current inrush after power-on. Speaker protection in case the amp goes DC.do you need this and soft start module as well?
Yup, they're pricey. I've got four of his earlier units myself. (The newer ones handle more powerful amps.)Ah that's more like it. About £70 per channel it appears though!
I have no problems with the Vellemans speaker terminals and vastly prefer them to the one's on the module you linked to. I wouldn't touch that with a bargepole TBH! A decent quality relay is more than that entire thing...
The vellaman kit is the cheap UK equivalent in price terms to these UPC1237 and I have had 2 of their cheap relays burn out on me
My advice is buy your own parts and relays for either kit from a reliable source.
How you would prefer a circuit board pin and a fine PCB track to a to a proper binding post directly connected to the relay for speaker cable is beyond me but there you go
Alan
I'll take a simple soldered connection over anything involving screws, that come loose, and probably dodgely crimped spade terminals to boot.
I would also prefer a good soldered connection and with the UPC1237 boards you can leave out the binding post and get a really good soldered connection to the PCB that has nice heavy tracks, but speaker cable to the Velleman pins na bollox
Alan
No I just said I would prefer it but the binding post in this application is still way better than a pcb pin IMHOChanged your mind about the screws then?
Changed your mind about those PCB pins and skinny PCB track have you ?.You could solder to the bottom of the relay pins on the velleman
No. You wanted to solder directly to relay and I pointed out that you can also do this with Velleman. If it had been the much inferior Naim product it would have had a 0.22R resistor in line anyhow!
When you remove the binding post there is a hole in the PCB with heavy duty double sided copper tracksleave out the binding post and get a really good soldered connection to the PCB that has nice heavy tracks
No I didn,t want to solder directly to the relay, read what I wrote?.
UPC1237 Speaker Protection Board Directly Mounted Hifi Amplifier DIY AC1 SQi4 | eBay
You will need to drill holes for the feet then bolt on. 5mm hole if memory serves.
lo I just dismantled my case to measure up for replacing the base panel with 4mm aluminium, was surprised how flimsy it was tbh. So asides from cooling will strengthen it a fair bit
