They're amazing little speakers. I bought a Rel T5i to use with mine, but ended up selling it. In a small room in nearfield they sound great, and while the sub added bass, it also took away some of the character of the speaker, so I decided I would rather do without the bass.
In the end I bought a pair of Graham LS6s as well, which are perfect in my small room and have more than adequate bass. I like these better than the LS5/9 which I also owned for a while. But I have kept the LS3/5s and listen to them from time to time because they do have the special magic that well-implemented tiny sealed boxes seem to possess.
@RossB How do the LS6 fare on contemporary material? As in, less than perfect productions, bass etc. Any comparisons to LS5/9 would be appreciated here too, thanks.
My usual speakers are Spendor SP100s so I guess I've been spoiled by a full range speaker so the LS3/5 do sound a little thin by comparison (I also listen to them in nearfield, which I think is when they sound best). But the Stadium II really does not get in the way that I can hear. The biggest impact that I hear the sub making isn't so much in the bass per se. It really is more in the dimensions of the sonic landscape (deeper, wider, etc). I use it with the SP100 too and it has a similar effect. But I also use DSP for room correction, which also tends to flatten out bass peaks and make the sub much less noticeable (as least when it comes to bass) so I'm sure that helps to make the sub less noticeable.
Still haven't heard the LS6 or LS5/9. Another speaker I've yet to hear is the Stirling LS3/6 (basically a modern BC1), which Derek Hughes designed as well. What I'm really interested in hearing the LS5/8. I'm wondering how it compares to the Spendor SP100 and the Harbeth M40.
That was a nice description eka. It’s reassuring that extra money does indeed buy greater SQ. I hadn’t heard of the LS8. Could you live with the Tablette, if you’d only heard it in isolation?
Today I could finally audition a pair of Graham Audio LS5/9, and although they are not LS3/5As – and they were connected to a monstrously costly Luxman/Tara Labs system – I think I had an idea of why the hype about BBC designs: they are probably the best stand mount loudspeakers I have heard so far. And they were not fully run in. I liked them a lot, and am now completely re-considering my listening habits, my options, my priorities.
I have the Graham LS5/9; very fine in a more open space than would suit an LS3/5a sized speaker.
I haven't compared the 5/9 to a Harbeth, Stirling or Spendor of similar size; that would be interesting.
To me, the Graham LS5/9 are a better balanced speaker than the M30.1 and 30.2. I find the transparency, clarity and detail of the Graham to be better than all Harbeth speakers in general. I surely prefer the LS5/9 more than the 30.1 which sounded to warm in the midrange with reduced air and extension in the treble. The M30.2 sounds more open than the 30.1 but the ls5/9 sounds even more open with better clarity and detail than the 30.2. Generally the sound of the Graham is airier and more extended in the treble. The Harbeth has a thicker and warmer midrange, a heavier bottom.Listening to them now; (Graham LS5/9s) - a little Van Morrison. Very nice indeed. Very satisfying. Haven't heard side by side with Harbeth Monitor 30.1, so I cannot speak to any appreciable difference.
and the enjoyment I get from my JR 149's
Hi Hook, I have Marten Duke 2 and yes I have briefly compared them to the Graham LS5/9, both with Luxman L-590AXII. I'm keeping both speakers. Generally the sound of the Marten is airier than the LS5/9 with a slightly smoother and more extended treble. The bass of the Marten goes deeper and is more defined. Both good and I can surely live with both. To me, the speakers have to be tonally accurate (apart from not sounding too warm or too bright) and both score very well here.Hi Ryder. Are you keeping your Marten Oscar Duos? If yes, have you had a chance to compare them with your LS5/9’s? Thanks!
Hi Hook, I have Marten Duke 2 and yes I have briefly compared them to the Graham LS5/9, both with Luxman L-590AXII. I'm keeping both speakers. Generally the sound of the Marten is airier than the LS5/9 with a slightly smoother and more extended treble. The bass of the Marten goes deeper and is more defined. Both good and I can live with both. I haven't had the chance to try the Naim with the Grahams yet. Tried the Naim with Marten and the result is not very good.
I still couldn’t tell you which I prefer between my JR149s and Falcon ‘gold crossover’ LS3/5As. They are both great, both have their own strengths and weaknesses. Technically I don’t need both, but I’ll likely never decide between them!
