I had the super micro with a leak stereo 20, great combination, until i had to sell them to fund my son's drumming career. I'm glad he's keeping the dual volume pots but £1,400 a pop is a bit step, it's not really value for money.
dual pots is a useless complication, it would certainly prevent me from buying.
Aside from that, Glenn has no problem finding customers and nor will he ever. Supply will always struggle to keep up with demand.
That is always an issue with niche manufacturers. Will he struggle equally with customer service?
I sort of see why it can be beneficial to the sound to have two separate volume pots for each channel
That's a better price and have to say sorry for not reading the info properly, i'm just glad that Glenn is making amps again so i'd better start saving. will the entry level have dual volume control's. p.s enjoy your ruby.
Hi Gregor,
Yes part of the cost saving is the use of the same casework across the range, so the cheaper pre will have dual mono just the same as the more expensive model. Other wise you have two holes in the fornt with one pot (which would probably violate CE codes). And thanks I will!
the engineering is here, now, and available to have one 'external' volume pot and a remote control - with no sonic degredation.
Let's consign the two-pots to the history bin of bad ideas.
Every time Croft has ever come up in conversation in twenty odd years the pain in the bum quality of the dual volume controls has been mentioned - this is THE defining feature for many and not in a good way.
