Pete the Feet
Hve you still got the 42.5? If so put it back in the system its a gem. Failing that cut out the crossovers and just try it with one NAP 250. Reduce the complications.
Just for the records... I have LP12 ITTOK/KARMA,Hercules, CDX, 82 with two HIs (another one for the Prefix), 250 and SBLs. Excellent bass! With the Allae that I had before the bass was many times too heavy. So I think that lack in bass is not a problem of the system - if the system functions as it should.
Arye
Active = better bass control, not less bass.
positive_energy asksid you ever do the comparison between 1 hicap and 2 on the 82?
Why would I delete 250 and Naxos? My task is to create an active system, and with the help of some people in PMF the sound has improved ..
NO NO you must go passive to get better performance from Naim now. One amp has better control of 4 drivers and a bunch of current sucking coils,caps and resisters. This is new Naim law, haven't you heard. So you just send me that 250 and I will dispose of it for you OK.
Hi Davide, just seen this thread - glad to see that you now have my old SBL's set up well and sounding good
