My floor is shaking now !!!!!
Is it shaking in TIME.
Putting things under electronics is a whole new sea. Personally I can't be bothered and I can't afford a Naim Fraim.
There seems to be no easy way to build one of Naim's sub-shelves yourself either
Jack
Does the glass sit on ball bearings like it does on the Fraim? The bit I cannot find is the bearing cup.
I refuse to buy these:
http://www.tomtomaudioshop.com/store/products.php?pid=64&detail=true
£16 each
PRAT PRAT PRAT PRAT
I hope that we helped you a bit pozz
Also good idea to get the right length NACA5 that is properly terminated with Naim plugs.
Try a piece of plywood under your CDP with any old ball bearings sitting in nuts underneath the plywood and resting on top of your existing support stand. This may provide some degree of sound improvement and it's even cheaper than Jack's rack.
yes,i thinking replaced my two pair of 3.5 Naca with 5/6 mt...
I could move further back the rack......
yes jack...Also way more freedom on speaker placement.
yes jack...
If his Ikea is not level will roll off eventually. My shelf is for such a purpose to level the glass perfectly. You have zero worries on this subject Mr Fraim
