Cereal Killer
432
Look forward to hearing your experiences when you've installed all of them! And had time to run them in a bit. What have they replaced?
They replaced some Rega cables I picked up for not a lot of money when sadly, a dealer died and his daughter was selling his stock off. Otherwise, I have used the German Loudspeaker shop Premium 4mm silver cables.
I'm essentially a skeptic about exotic speaker cables. Down the years I've tried a couple on loan and they were different to what I already had without being outright all round better than those I was already using. These are the first I have tried that are immediately obviously better than those I own without losing something that the incumbents provide. Probably the best compliment I can pay the LS-25 cable is that, it doesn't have any real sound of its' own which, in the final analysis, is probably what the designer is seeking?
Why wouldn't they, be good to know. I was told that 3m cables is the minimum but my kit is right next to each other, if they offer a 1m option that is fine by me I don't need to spend more as it isn't needed.
Is there a rule as such then to SC lengths? Be good to know some thoughts?
I'm of the opinion if the actual maker of the cable offers a 1m version then it must be ok, am I wrong here :-(
Dan, don't forget the distance from the floor to the speaker terminals!
Isn't that what the cable spacers are for? Sound quality is much better if you can run the cables in a straight line instead of having bends in the cable - think about the phase errors caused by part of the signal taking the outer curve while another part takes the inner curve!
The Sopra are on the bottom so same level as the amp, kind of leaves me stuck if I change the speakers mind Thinking.....
Colin Wonfor is certainly no 'subjectivist quack'
