Cereal Killer
432
Is your shill wire not running in an analogue system, or are you confused about perfection?
From looking at the amount of threads you crap on, you must be really full of shit....
Did you get them in M&S?
1m set? How's that work with the 130pro?
1m speaker cables seems incredible, unless you have monoboloc amps.
Seems like with the bends required in the cables your speakers could only be about 4ft apart? Even then, the cables will be suspended in mid air.
Well not sure the speakers are positioned as per room correction software, wall placement etc etc, bass traps you name it, the 3m NACA5 is all over the flaming place and annoying me so 1m works for me and cheaper too. Skinny rectangular room size its fine and working for me after weeks of pissing about
Dan - you got some pics of the way its setup and room?
What the distance between the speakers and how far away do you sit from them?
